Smarthings Multi sensor no magnet output
I just purchased have tried adding a samsung smart things multi sensor with ZHA, the binary sensor for the magnet did not get setup, I am also not getting and zha events for the contact sensor, xyz motion, temp and water? show correct, any ideas?
OK after some reseach I found out this does not have a humidity sensor and the magnet is labeled incorrectly as a water sensor, I still do not understand why I cannot see a zha event when it it opened and closed but I can see it respond under zha
Now the question becomes how do I correct this?
