Smarthings pulling my hair out
Hi another new user here…
Been trying to get smartthings integration working and failed so far… I have setup Lets encrypt addon and duckdns addon yet I still get this message…
This is my configuration.yaml
Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
base_url: https://*********.duckdns.org:8123
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
Here is lets encrypt log
INFO: Selected http verification
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Processing /data/letsencrypt/renewal/***********.duckdns.org.conf
Cert not yet due for renewal
The following certs are not due for renewal yet:
/data/letsencrypt/live/********.duckdns.org/fullchain.pem expires on 2020-05-20 (skipped)
No renewals were attempted.
And finally here is my duckdns log
Config
1
lets_encrypt:
2
accept_terms: false
3
certfile: fullchain.pem
4
keyfile: privkey.pem
5
token: 85a4f1ff-6344-462a-943e-***************
6
domains:
7
  • *********.duckdns.org
8
seconds: 300
9
RESET TO DEFAULTSSAVE
Log
[05:08:38] INFO: OK 81.155.52.194 NOCHANGE [05:13:39] INFO: OK 81.155.52.194 NOCHANGE [05:18:40] INFO: OK
As far as I can workout all these seem ok but I still get the base url error when trying to add the integration… Any help would be gratefully received
Thank you Danni…
