Smarthings using cloudhook or webhook
I just upgraded from 0.89.2 to 0.90. Have Smartthings working with the config from 0.89.2. I added the HA Cloud two days ago. The docs for 0.90 say:
" If you have previously setup the component prior to meeting the requirements for a cloudhook or prior to v0.90.0, you must remove all prior integrations and run through the configuration again."
Is it really necessary to redo this again? I haven’t done it yet and the prior config seems to be working fine with 0.90. This would be the third time I’ve had to redo the Smartthings integration and it’s getting a little tiring.
