Hi all.
Finally, I got the IR codes of my 3 climas, then I tried to create my JSON file and configure the first one to work with HA.
This is what I did:
#CONFIGURAZIONE SMART IR
smartir:
#Climatizzatore 1
climate:
- platform: smartir
unique_id: AC_BatCaverna
device_code: 9000
controller_data: remote.ir_batcave_remote
#temperature_sensor: sensor.temperature
#humidity_sensor: sensor.humidity
#power_sensor: binary_sensor.stato_accensione
After restart, I found the new entity, and it works. More or less, but now is just a problem concerning the JSON file (the syntax), but I can at least switch the clima ON and OFF.
Then, I tried to add a second clima:
smartir:
#Climatizzatore 1
climate:
- platform: smartir
device_code: 9000
#Climatizzatore 2
- platform: smartir
unique_id: AC_Sala
device_code: 9002
controller_data: remote.ir_fm_sala_remote
But now I can’t find the second entity, just the first one is present and working.
I don’t understand why, I think everything is well configurated, but nothing to do.
Any solution / suggestion ?
