After I discovered that Broadlink “sniffs” all the traffic in my network, I decided to replace it with zigbee UFO-R11. But I really do not want to manually learn the codes. Does anyone know how to convert existing codes to codes for UFO-R11 MQTT.
Good afternoon. Tell me can I use smart ir s08 tuya if so how? Thank you.
Is SmartIR still being maintained?
Seems like there are many areas that are unpolished and there hasn’t been any changes in a long time.
For example, creating devices formally instead of just registering an entity to HASS (this will allow complex devices like fans with lights). Also, UI configuration.
Yup. Works just fine now. Guess I’ll be joining you in trying to figure out how to convert codes for the UFO-R11 MQTT because I don’t have the remote and I’m not looking forward to teaching the AC code combinations either.
I did not advance in the conversion of codes, but facilitated the learning procedure with a script.
script:
lerning_script:
- repeat:
for_each:
- "heat powerful 18" #this is the name of the code that will be in the notification HA
- "heat powerful 19"
- "heat powerful 20"
- "heat powerful 21"
- "heat powerful 22"
- "heat powerful 23"
- "heat powerful 24"
- "heat powerful 25"
- "heat powerful 26"
- "heat powerful 27"
- "heat powerful 28"
- "heat powerful 29"
- "heat powerful 30"
- service: persistent_notification.create
message: "Wait code for {{ repeat.item }}"
notification_id: "55555"
- variables:
ircodetimestamp: "{{ as_timestamp(states.sensor.<NAME YOUR DEVICE>_learned_ir_code.last_changed) }}"
- service: mqtt.publish
topic: zigbee2mqtt/<NAME YOUR DEVICE>/set
payload: '{"learn_ir_code": "ON"}'
- wait_template: "{{ ircodetimestamp != as_timestamp(states.sensor.<NAME YOUR DEVICE>_learned_ir_code.last_changed) }}"
timeout: 10
- service: notify.ir_code
message: "{{ repeat.item }}, {{ states('sensor.<NAME YOUR DEVICE>_learned_ir_code') }}"
notify:
- name: ir_code
platform: file
filename: ir_codes.csv #file in the config folder where all the codes will be written
For some reason, the Smartir developer does not accept codes for MQTT. These are my codes for GREE air conditioners.
"manufacturer": "Gree",
"supportedModels": [
"Unknown"
"supportedController": "MQTT",
"commandsEncoding": "Raw",
"minTemperature": 18.0,
"maxTemperature": 30.0,
"precision": 1.0,
"operationModes": [
"cool",
"heat"
"fanModes": [
"auto",
"sleep",
"powerful"
"commands": {
"off": {"ir_code_to_send": "ByUjgBGUAjICgAMDbwaUAsAL4AcHQBvAA+AHG+AHD0An4AcT4AMPwB/AB0AbwAsDKU6UAkAP4CEDQAEBlAKAP0ABAZQC4AED4BMB4AMnDZQCbwYyAm8GMgJvBpQC"},
"cool": {
"auto": {
"18": {"ir_code_to_send": "CzIjnRGIAnAGiAIuAoAD4AMLwBNAB+APF0Ab4CcDwEvAB0A/gAsHLgIxTogCLgLgKQOAPwGIAuArA0A7C3AGiAJwBogCLgKIAg=="},
"19": {"ir_code_to_send": "C00jYxGQAmgGkAIpAoAD4AML4AMT4AsXwB/gJwfAS8AHQD/ACwMqTpACQA/gEQNAAeAHHwEpAsA/ASkC4DUDA2gGkAI="},
"20": {"ir_code_to_send": "C0EjgBGcAmEGnAIbAoAD4AMLwBPAB+ATG8Aj4BsHwEfAB0AzwAsDFE6cAkAP4CcDwD/gJzdAL+ABOwUbAmEGnAI="},
"21": {"ir_code_to_send": "C94igBGbAmYGmwIdAoAD4AML4AcT4AsbwCPgIwfAR8AHQDvACwMTTpsCQA/gJwPAP+AnN4AvDR0CZgabAh0CHQJmBpsC"},
"22": {"ir_code_to_send": "C0EjgBGWAmsGlgIgAoAD4AMLwBNAB0AXQANAC+A3A8BHwAdAT8ALAyJOlgJAD+AnA8A/4Cc3QC9AOwtrBpYCIAKWAmsGIAI="},
"23": {"ir_code_to_send": "Cz4jgBGZAm0GmQIeAoAD4AML4AMTQBdAA8AT4DMHwEfAB0BLwAsDCU6ZAkAP4CcDwD/gJTfAAYA3B20GmQJtBpkC"},
"24": {"ir_code_to_send": "CzwjbxGQAnAGkAJDAoAD4AMLwBPgAwfgFx/gAStAAeADD0ALgAGAQwFDAoAHgBfACwNHTkMC4CkBBZACcAZDAuAFAQGQAuABA8AB4AMT4AELD3AGkAJDApACcAaQAnAGkAI="},
"25": {"ir_code_to_send": "C0EjhRGXAmwGlwIiAoAD4AML4AsT4AsfwCfgHwfAQ8AHQDfACwMtTpcCQA/gJwPAP+AhN0ABQC+AAQtsBpcCbAaXAmwGlwI="},
"26": {"ir_code_to_send": "C0EjgBGaAmwGmgIfAoAD4AMLwBNAB8AXwAdAE+AvA8BDwAdAR8ALAx5OmgJAD+AnA8A/4Bk3QAHgBSdAOwtsBh8CbAaaAmwGHwI="},
"27": {"ir_code_to_send": "C9cifRGZAmoGmQIcAoAD4AML4AMTwBfAB8Ab4CsHwEPAB0BDwAsDL06ZAkAP4CcDwD/gJzcAHGABQAcJmQIcApkCHAKZAg=="},
"28": {"ir_code_to_send": "Cx4jnBGKAncGigIqAoAD4AMLwBPAB0AbQAPAD+AvB8BDwAdAR8ALAztOigJAD+AnA8A/4Cc3QC/gBDsCAooC"},
"29": {"ir_code_to_send": "C0EjghGXAmMGlwIdAoAD4AML4AcTQBtAA8AX4C8HwEPAB0BHwAsDHE6XAkAP4CcDwD/gJzfALwtjBpcCHQKXAh0ClwI="},
"30": {"ir_code_to_send": "C0gjgBGeAlsGngIXAoAD4AMLwBNAB0AXwANAD+AzA0BHQD/AB+ADCwMUTp4CQA/gJwPgA0vgKzsLWwaeAhcCngIXAp4C"}
"sleep": {
"18": {"ir_code_to_send": "C0EjjBGTAnYGkwIfAoAD4AMLQBPAD8AHQBPgNwPAS8AHQE/ACwMqTpMCQA/gJwPAP+AnN0AvQDsLdgaTAnYGkwIfApMC"},
"19": {"ir_code_to_send": "Cw8jfhGWAmMGlgIgAoAD4AMLQBNAD8ADQA/gOwNAT0BHwAfgBAsAToAPASAC4CUD4ANL4A07QAHgDxvgARcDYwaWAg=="},
"20": {"ir_code_to_send": "C9kibRGPAnoGjwJKAoAD4AMLQBPgAw/gAwtAG+ANA0ABQBvgEQEDegZKAkABwAdAAQF6BoAzA0dOSgLgHQFAL+ABAwd6BkoCSgKPAoADQAHAC+ALB8ABQBsDSgJ6BoAHB0oCSgJ6BkoC"},
"21": {"ir_code_to_send": "CzIjdhGRAnQGkQJIAkADAUgC4AELQA8BkQJAD0ADwAtAB+ApA0AB4AE34AtPwBMELU6RAkjgKgEDdAZIAuAVAeAHV0APQAOAAQt0BkgCSAKRAnQGSAI="},
"22": {"ir_code_to_send": "C0MjghGYAmsGmAIbAoAD4AMLQBPAD0AHQANAE+A3A8BHwAdAT8ALAy1OmAJAD+AnA8A/4Cc3QC9AOwtrBpgCGwKYAmsGmAI="},
"23": {"ir_code_to_send": "CzUjixGcAmcGnAIeAoAD4AMLQBNAD+ADA0AT4DcDQE9AQ8AH4AMLAw9OnAJAD+AnA+ADS+AnO4AvCR4CZwYeAmcGHgI="},
"24": {"ir_code_to_send": "Cx4jjxGRAncGkQIhAoAD4AMLQBPgFw9AI+AnA8BTwAdAP8ALAzZOkQJAD+AnA8A/4Cc3QC/AOwd3BpECdwaRAg=="},
"25": {"ir_code_to_send": "CwMjfhGfAmQGnwIbAoAD4AMLQBNAD0ADQAtAA+ADC0AP4CsDwEPAB0BDwAsDD06fAkAP4CcDwD/gFTdAAeANIwtkBhsCZAafAmQGGwI="},
"26": {"ir_code_to_send": "C0EjgBGbAnUGmwIgAoAD4AMLQBPAD+AHB0Ab4C8D4AtLwBMDEU6bAuArV8A/4CU7gAEBdQbgAgMCBpsC"},
"27": {"ir_code_to_send": "C0EjgBGfAlsGnwIlAoAD4AMLQBNAD8ADwA9AB+AzA0BPQD/AB+ADCwMSTp8CQA/gJwPgA0vgHTvgDgECAiUC"},
"28": {"ir_code_to_send": "C0MjYxGUAmsGlAI6AoAD4AMLQBPgAw9AC0ADQBfgMwPAQ8AHQEvACwMlTpQCQA/gIQOAAYA/4CcBgGcPawY6AjoClAI6AjoCOgI6Ag=="},
"29": {"ir_code_to_send": "DTojbhGRAnAGRwJHApECQAMDcAaRAkAHwANAD0ADQA9AB0ADQAvgMwPAQ8AHQEvACwMtTpECQA8AR+AmAQNwBkcC4BkB4AtXQBMNkQJwBkcCRwKRAkcCRwI="},
"30": {"ir_code_to_send": "C+ginRGEAnwGhAIvAoAD4AMLQBPAD0AHwANAF+AzA0BHQD/AB+ADCwNAToQCQA/gJwPgA0vgKzsLfAaEAi8ChAIvAoQC"}
"powerful": {
"18": {"ir_code_to_send": "C0MjjRGTAnAGkwIgAoAD4AMLwBNAB+APF0Ab4AcD4BcrwB/AB0A/wAsDL06TAkAP4CcDwD/gJzdAL0A7C3AGkwJwBpMCIAKTAg=="},
"19": {"ir_code_to_send": "CwUjgBGZAmAGmQIgAoAD4AML4AMT4AsXwB/gBwfgFyvAH8AHQD/ACwMZTpkCQA/gJwPAP+ARN0AB4AcfQAHgBRMDYAaZAg=="},
"20": {"ir_code_to_send": "C8oijxGTAncGkwIjAoAD4AMLwBPAB+ATG8AjQAfgFyfAH8AH4AMzAyxOkwJAD+AnA+ADS+AdO0ABgCvgAzsDdwYjAg=="},
"21": {"ir_code_to_send": "CzQjdhGQAnUGkAJHAoAD4AML4AcT4AsbwCMAR2ABgAcFdQZHAkcCQAtAA0ABwAeAAYAfA0cCdQZAF0ADAUcCwAsDSk5HAuAdAQKQAkdgAUAHBZACdQZHAuAFAQGQAuAFA0AB4A8TDUcCdQaQAkcCkAJ1BpAC"},
"22": {"ir_code_to_send": "C8simBGJAnwGiQIpAoAD4AMLwBNAB0AXQANAC+AXA+AXJ8AfwAdAT8ALAzhOiQJAD+AnA8A/4Cc3QC9AOwt8BokCKQKJAnwGiQI="},
"23": {"ir_code_to_send": "CTIjmxFSAnwGUgLAAQV8BpECUgLAA4ABAXwGQAMAkSAHA5ECUgLgCwNAAUAXgAHgASfgDQEDfAZSAkABwAdAAQF8BoA/A0NOUgLgKwEDfAZSAuABAYBLAVICQAfgCwNAAeADF4ABB3wGUgJ8BlIC"},
"24": {"ir_code_to_send": "C0gjYhGSAnUGkgJGAoAD4AMLwBPgAwfgFx9AK+ARI0AB4AEf4AMnwAsDME6SAkAj4AUD4BkBA3UGRgLgDQFAS+AVAcA7B3UGRgJ1BkYC"},
"25": {"ir_code_to_send": "C0EjiRGaAmoGmgIZAoAD4AML4AsT4AsfwCdABwO4AZoCgCMBCQNACwIZAppgAcALQA8BagaAGwNqBpoCQA8DmgIZAsALBTNOmgIZAuApA8A/4Cs7QDMLagaaAmoGmgJqBpoC"},
"26": {"ir_code_to_send": "CwAjgRGgAmwGoAIfAoAD4AMLwBNAB8AXwAdAE+APA+AXI8AfwAdAR8ALAxFOoAJAD+AnA8A/4CU3gAEBbAbgAgMCBh8C"},
"27": {"ir_code_to_send": "C94ikRGGAogGhgIvAoAD4AML4AMTBYgGLwIvAkAHAYYCQAfgEwPgASNAAQGGAuAHA8AfwAdAH8ALAztOhgJAD+AnA8A/4Cc34AgvAgKGAg=="},
"28": {"ir_code_to_send": "CzwjbBGPAnAGjwI8AoAD4AMLwBPAB0AbQAPAD+APB+AXI8AfwAdAR8ALAy9OjwJAD+ANA+ALAUArBzwCcAY8AjwCgAvgBQHgAxNAC+AJAw9wBo8CPAI8AjwCPAI8AjwC"},
"29": {"ir_code_to_send": "C0EjghGWAmsGlgIkAoAD4AML4AcTQBtAA8AX4A8H4BcjwB/AB0BHwAsDLE6WAkAP4CcDwD/gJzcAJKABC2sGlgIkApYCJAIkAg=="},
"30": {"ir_code_to_send": "CzwjZRGYAmsGmAIyAoAD4AMLwBNAB0AXwANAD+ATA0An4Bsf4AMnwAsDG06YAuATO+APG4A/QAEBmALgBQPgFwEEmAJrBjJgAwcyApgCMgIyAg=="}
"heat": {
"auto": {
"18": {"ir_code_to_send": "BzIjdBGPAkgCgAMBdwaAA8AP4AMHQBvgAw/gFQtAAUAj4A0BA3cGSAJAAcAHQAEBdwaALwNATkgC4BkBQCvgBQOAPwGPAuAVA+ADAUAr4AEBC3cGSAJIAo8CdwZIAg=="},
"19": {"ir_code_to_send": "B0EjjhGTAh8CgAMBdAaAA8APwAfgDxfAH+AnB0BPQDPAB+ADCwMvTpMCQA/gJwPgA0vgKzsLdAaTAh8CkwJ0BpMC"},
"20": {"ir_code_to_send": "B0EjlBGUAh8CgAMBeQaAA8AP4AcHQB/gBxPgKw/AR8AHQEPACwMxTpQCQA/gJwPAP+AnN+ADLwd5Bh8CeQaUAg=="},
"21": {"ir_code_to_send": "BygjbRGPAkECgAMBdAaAA8APwAdAF0ALwAdAC+AzAwV0BkECQQJABwKPAkFgAQGPAoALBY8CRU5BAuApAQWPAnQGQQLgCQEBjwLgGwMPdAaPAkECQQJ0Bo8CdAaPAg=="},
"22": {"ir_code_to_send": "BxkjnBGKAikCgAMBeQaAA8AP4AMH4BMb4AMn4BsLQEtAJ8AH4AMLAzhOigJAD+AnA+ADS+AnO0AvC3kGigJ5BooCeQaKAg=="},
"23": {"ir_code_to_send": "B0MjgBGYAh4CgAMBaAaAA8APwAfAF0AHwBPgMwfAR8AHQEvACwMfTpgCQA/gJwPAP+AnN0AvQDsLaAaYAmgGHgJoBpgC"},
"24": {"ir_code_to_send": "B0MjYxGRAjoCgAMBcAaAA8AP4AsHQCPgCxfgIRMBOgLAQ8AHAzoCkQLACwMtTpECQA/gCQPgFQEDcAY6AuAFAUBDwAFAC+AbAwU6AjoCkQI="},
"25": {"ir_code_to_send": "B0AjhhGVAiACgAMBcAaAA8APwAdAF+ALC8AT4CcHwE/AB0A/wAsDDU6VAkAP4CcDwD/gJzdAL+AEOwICIAI="},
"26": {"ir_code_to_send": "B0EjjhGUAh4CgAMBcwaAA8AP4AMHQBtAD8AHQAvgLwPAQ8AHQEfACwMuTpQCQA/gJwPAP+AnN8AvC3MGlAIeApQCHgKUAg=="},
"27": {"ir_code_to_send": "B0AjgBGaAh0CgAMBYAaAA8APwAfgAxdAC8AX4C8HwEPAB0BHwAsDMk6aAkAP4CcDwD/gJzdAL0A7C2AGmgIdApoCHQIdAg=="},
"28": {"ir_code_to_send": "B0AjkBGWAh8CgAMBbwaAA8AP4AcH4Bcf4Acv4A8PQEdAG8AH4AMLAzlOlgJAD+AnA+ADS+AnO8AvB28GlgIfAh8C"},
"29": {"ir_code_to_send": "B8AiehGPAkUCgAMBdAaAA8APwAdAF0ALQAdAA0AL4CEDQAHgBS/AQ8AHQB/ACwNKTkUC4CsBA3QGRQLgAQECjwJF4AgBQBPgBwNAARGPAnQGjwJFAkUCdAZFAkUCRQI="},
"30": {"ir_code_to_send": "BxUjgBGaAhsCgAMBYQaAA8AP4AMHwBtAB+ADF+ArC8BDwAdAQ8ALAx1OmgJAD+AnA8A/4Cc3wC8LYQaaAmEGmgIbApoC"}
"sleep": {
"18": {"ir_code_to_send": "B0EjZRGSAjsCgAMBcgaAA8APQAdAE+ADB0AL4DcD4AtTwBMDK06SAuAVX+ADAUArgAEDcgY7AuAJAUAfQANAAUAHwANAAUALQAGABwtyBjsCOwI7AnIGOwI="},
"19": {"ir_code_to_send": "B74idBGQAkICgAMBcwaAA8APQAfAE0AHQA/gKQNAAcA3gAGASwFCAoAHgBvACwNLTkIC4BEBApACQuAIAYATA3MGQgKAAUAP4BcDQAHgASMBcwZAAwlCAkICQgJzBkIC"},
"20": {"ir_code_to_send": "B0AjmRGMAiYCgAMBegaAA8APQAdAE0AHQAPgAwtAD+AvA8BHwAdAR8ALAzFOjAJAD+AnA8A/4Cc34AMvB3oGjAJ6BowC"},
"21": {"ir_code_to_send": "BzcjbhGRAkYCgAMBdAaAA8APQAfgAxNAC0AT4DcDwEfAB0BPwAsEL06RAkbgKgEDdAZGAuAhAUBj4AEDD3QGkQJGAkYCdAZGAnQGRgI="},
"22": {"ir_code_to_send": "B0YjgBGWAh4CgAMBcgaAA8APQAdAE8AHwAtAD+AzA8BHwAdAS8ALAzBOlgJAD+AnA8A/4Cc3wC8LcgaWAnIGlgJyBh4C"},
"23": {"ir_code_to_send": "B94iYxGHAhgCgAMBbQaAA8APQAfAEwJtBrlgAwEYAsADA4cCGAJAC0AH4CUDA20GhwJAM8AH4AMLAyNOhwJAD+AnA8BLQAHgBzvgFwFAOwttBocCbQaHAm0GhwI="},
"24": {"ir_code_to_send": "B0EjgBGaAh4CgAMBVwaAA8APQAdAE0AHwAPgBw/AF+AjB8BDwAdAO8ALAxdOmgJAD+AnA8A/4B03QAHgDisCApoC"},
"25": {"ir_code_to_send": "Bw0jahGTAkECgAMBcQaAA8APQAfgBxNAD0AX4DMDwEPAB0BLwAsDLU6TAkAP4AEDQAFAD+AVAQNxBkEC4BUBQEPgAwNAAUAPAUEC4AQ7AgJBAg=="},
"26": {"ir_code_to_send": "B+YigBGdAh4CgAMBYwaAA8APQAdAE+ALB0AT4C8D4AdTQEfAEwMZTp0CQA/gJwPAP+AdN0AB4AUrC2MGHgIeAp0CHgIeAg=="},
"27": {"ir_code_to_send": "BzwjmBGIAisCgAMBeQaAA8APQAfAE0AHwA9AB+AzA+ALS8ATAztOiALgK1vAP+AvOwt5BogCKwKIAisCiAI="},
"28": {"ir_code_to_send": "BzcjgBGeAiACgAMBWQaAA8APQAdAE0AHQANAC0ADQAvgMwPAQ8AHQEvACwMYTp4CQA/gJwPAP+AZN0ABQCdAAeADBwmeAlkGngIgAiAC"},
"29": {"ir_code_to_send": "B7IigBGbAh4CgAMBYAaAA8APQAfgAxPgAwtAG+AvA0BHQDvAB+ADCwMdTpsCQA/gJwPgA0vgLTsJHgJgBh4CHgKbAg=="},
"30": {"ir_code_to_send": "BygjghGUAigCgAMBdwaAA8APQAdAE8AHQAtAA0AP4DMDwEPAB0BLwAsDL06UAkAP4CcDwD/gETdAAeAHH+ABAQt3BigCdwaUAigClAI="}
"powerful": {
"18": {"ir_code_to_send": "B+MimxGMAicCgAMBdwaAA8AP4AMHQBvgAw/gEwvgFyvAH8AHQEvACwM2TowCQA/gJwPAP+AnN8AvC3cGjAInAowCdwaMAg=="},
"19": {"ir_code_to_send": "B0MjgBGTAiUCgAMBbgaAA8APwAfgDxfAH+AHB0Av4AcT4AMPwB/AB0Ab4AALBE6TAiUC4CkD4AA/YAEBkwLgIwNAOwtuBpMCJQKTAm4GJQI="},
"20": {"ir_code_to_send": "B+gigBGbAhsCgAMBZgaAA8AP4AcHQB/gBxPgCw/gFyfAH8AHQEPACwMVTpsCQA/gJwPAP+AnN+ADLwdmBhsCZgabAg=="},
"21": {"ir_code_to_send": "B9kiYBGRAkICgAMBdgaAA8APwAdAF0ALwAdAC+ATA+AXJ8AfwAdAS8ALAyxOkQJADwBCYAFAB8AD4BUBA3YGQgLgJQHAVxGRAnYGkQJCApECdgZCAnYGQgI="},
"22": {"ir_code_to_send": "By8jihGeAhcCgAMBXQaAA8AP4AMH4BMb4AMnQAtAK0AH4A8DwB/AB0AnwAsDFk6eAkAP4CcDwD/gJzfALwtdBp4CXQaeAl0GngI="},
"23": {"ir_code_to_send": "BxIjYxGUAiYCgAMBbQaAA8APwAfAF0AHwBPgEwfgFyfAH8AHQEvACwMgTpQCQA/gGQNAAeABJ8A/4AMT4B8LQDsLbQYmAm0GJgJtBpQC"},
"24": {"ir_code_to_send": "B0EjgBGbAhwCgAMBWAaAA8AP4AsHQCPgCxfgAxPgFyPAH8AHQDvACwMbTpsCQA/gJwPAP+ARN0AB4BMfCZsCHAKbAhwCmwI="},
"25": {"ir_code_to_send": "B0AjgRGUAigCgAMBZAaAA8APwAdAF+ALC8AT4AcH4AMv4AcbQA/AH8AH4AMTAyNOlAJAD+AhA0ABAZQCgEtAAQGUAuAFA0AB4BUTgDsJlAIoApQCKAKUAg=="},
"26": {"ir_code_to_send": "ByMjghGVAi8CgAMBagaAA8AP4AMHQBtAD8AHQAvgDwPgFyPAH8AHQEfACwMlTpUCQA/gIQNAAQGVAsA/QAsAL2AB4AcH4AMBQBtAA0ABQAcNlQJqBi8CLwKVAi8ClQI="},
"27": {"ir_code_to_send": "B+UihhGVAh4CgAMBcgaAA8APwAfgAxdAC8AX4A8H4BcjwB/AB0BHwAsDLk6VAkAP4CcDwD/gJzdAL0A7C3IGlQIeApUCHgKVAg=="},
"28": {"ir_code_to_send": "B0EjghGSAiUCgAMBaQaAA8AP4AcH4BcfwC9AJ8AL4AsHwB/AB0AjwAsDJk6SAkAP4CcDgD9AAQGSAuAvAwdpBpICJQKSAg=="},
"29": {"ir_code_to_send": "B+EiahGTAkICgAMBcQaAA8APwAdAF0ALQAdAA0AL4BMD4BcjwB/AB0BLwAsDLk6TAkAP4BUD4AkBA3EGQgLgLQEBkwLAOwdxBkICQgJCAg=="},
"30": {"ir_code_to_send": "B8sibxGPAjkCgAMBcwaAA8AP4AMHwBtAB+ADF+ALC+AXI8AfwAdAQ8ALAypOjwJAD+AVA8ABQCeAAQNzBjkC4AkB4AEfgAFAD+ANAwtzBo8CcwY5AjkCjwI="}
Where’re you executing this script because my HA isn’t having it when I try to paste it in
Message malformed: invalid template (TemplateSyntaxError: expected name or number) for dictionary value @ data['sequence'][0]['repeat']['sequence'][1]['variables']['ircodetimestamp']
I saved it as a yaml file, rebooted HA and saw this script in the settings. Most likely you have an error in the line ircodetimestamp: "{{ as_timestamp(states.sensor.<NAME YOUR DEVICE>_learned_ir_code.last_changed) }}"
send her
Hi, I have smart IR with one AC that works great. How can I disable heating mode because there is another heating system. And what is better is to group the AC and heating into one climate card. The heater is controlled by a Nest thermostats also integrated with google Nest into home assistant. Thx
Any updated tool to create customs .json for Smart IR?
Hi, I am facing an issue which I’m unable to fix, seeking help from the community to point me to the right direction.
Setup:
- Broadlink Mini RM4 connected to HASS and using SmartIR for controlling my Sony Bravia TV.
- Exposed the TV remote to Homekit via Homekit Bridge
Issue:
When I use the “remote” functionality in iOS then my TV responds to the command but then immediately turns off. This happens for any command. For example, if I try to increase the volume then I can see the volume go up and then immediately the TV turns off. Seems like there’s an additional command that is being sent when I’m trying to use the iOS remote feature.
I’m able to control the TV and all its functionality without any issue via the HomeAssistant dashboard. The issue only happens with iOS. So I’m not doubting the SmartIR plugin configuration issue but not able to figure out what could be the issue. Please help.
Thanks,
Made any progress @Tranquilizer? Bit the bullet & manually added all the codes to my json & only “off” works for me. Such a PITA
How to create a proper fan json file?
I can’t figure out how to create a proper json file for the fan codes. I have my IR codes working, but how to create a correct file? I tried to peek into the files of the other codes and create a similar one with another numbering of my choice (for example 2000), but it seems that using this last one the smartir integration is not loaded correctly; therefore I assume that some steps are missing.
"manufacturer": "Brandson",
"Unknown"
"supportedController": "Broadlink",
"commandsEncoding": "Base64",
"speed": "toggle"
"commands": {
"power": "JgAsAScOKA4NKCgNKQ0NKA4oDSkNKA4oDSko4ikNKA0OKCgOKA0OKA0pDSgNKQwqDCkoAAEGJw4oDgwpKA4oDQ0oDigNKA4oDSkNKCjkKAwoDg0oKA4oDgwpDSkNKA4oDCoMKSgAAQYoDSgODSgoDigOCyoNKAwpDigOKA0oKOQoDSgNDCkpDSgODSgOKA0oDigNKQ0oJwABBygNKA4NKScOJw8MKQ0pDCgOKA0pDSgo5CgNKA4MKCkNKQ0NKA0pDSgOKA0pDSgoAAEGKA0oDg0pJw4oDg0oDCoMKgwoDigNKCjkKA0oDgwqJw4oDQ0pDSgNKQ0oDigNKSgAAQUnDygNDigoDigNDigNKQsqDSkLKg0oKeMnDigOCyooDigODCgNKQ0pDSgNKQ0pJwANBQ==",
"speed": "JgAsAScOJw4OKCgNKQ0MKgwpDSgNKQ0oKQ0N/igOKA4MKScOKQwOKA0pDSgOKA0pKA0OAAEgKA4oDQ4oJw4oDg0pCyoNKQwqDCgpDQ3/Jw4oDg0oKA4oDgwoDigNKQ0oDigoDQ4AASEoDSgNDigoDigNDigNKQ0oDCoMKicODP8oDSgODSknDigODCoMKQ0oDSkNKCgODQABIicOJw4NKCkNKA4NKA4oDSkNKA4oKA4M/igOJw4OKCgOJw4NKQ0oDSkNKQwoKQ0NAAEiJw4oDgwpKA0pDQ0oDigNKA4oDSkoDQ3+KA0pDQ0pJw4oDgwpDSkNKQwpDSknDg0AASEoDigNDSkoDicODSgNKA4oDSkNKCgODf4oDicODSgpDSgNDigNKQwpDigNKScODAANBQ==",
"Oscillate":"JgAsASgNJw8MKicOKA0NKA4oKA0OKA0pDSgO/SkMKQ0NKSgNKA4NKA4oKA4NKA0pDCoMAAEhKA4oDQ4oKA4nDg0oDSgpDQ0pDSgOKA3+KA0pDQ0oKQ0oDQ0pDSkoDQ4oDSgNKQ0AASEoDSgODSknDigODCkNKSgNDSgNKQ0oDv4oDSgODCkoDSgODSgOKCgODCkOKA0pDAABIScPJw4OKCgOJw4OKAsqKA4MKQ0oDigN/ycOJw8MKScPKAwOKA0pJw4NKQ0oDigNAAEhKQwoDg0oKA4oDg0oDigoDQ0pDCoMKA7+KA0oDg0pKA0nDwwoDigpDQ0oDigNKQwAASIoDSkMDignDycODSkNKCgODSkLKg0pDP4oDigODSgoDicODSkMKicNDSkNKQ0oDgANBQ==",
"Led":"JgAsASgNKA0OKCgOJw4NKSgNDSkMKgwpDSgN/igOKA0NKScPJw4NKCkMDigNKQ0oDigNAAEhKA0pDQwpKA4oDQ4oKA4NKAwqDCoMKQ3+KA8mDg0oKA4oDgwpJw4NKA0pDSkNKA4AASEoDSgNDSkoDSgODSgoDg0pDSgOKAwpDf4oDicODSkoDSgODConDgwqDCgOKA0pDAABIigOKA0NKCkNKA0NKSgNDSkNKQ0oDigN/SkNKA4NKCgOKA0OKCgODCkMKgwoDigNAAEiJw4oDgwpKA4oDQ0oKQ0MKQ4oDSkNKA3+KQwpDQ0pJw4nDw0oKA4NKQwpDSkMKgwAASEnDygNDSkoDicODCkpDA4oDSkNKA0pDf8nDigNDCkpDScODigoDg0oDSkNKQsqDAANBQ==",
"Timer":"JgAsASgNJw8NKScOKA4MKA4oDignDg4oDSgN/ygOJw0OKCkMKA4NKQ0oDigoDQ4oDCoLAAEjKA0oDg0pJw4nDwwpDSkMKSgNDigNKA7+KA4nDgwpKQwpDQ0pDSgNKSgODSgOKAwAASIoDSgODSknDigODSgNKQwqKA0NKA0pDf4nDygNDSknDycODCkMKQ0pKA4NKA4oDQABISkMKA4NKScOKA4NKA0pDSknDgwqDCoM/igOJw4NKScPJw4MKgwoDigpDQ0oDigMAAEjJw4oDQ0pJw4oDg0pDCkNKSgNDCoMKgv/Jw8nDg4oJw8nDg0pCyoNKScODCkNKQwAASMoDSgODCooDCgODSgOKA0pKA0OKA0pDf0oDigNDSkoDicODSkMKQwqJw8MKQ0oDQANBQ==",
"Mode":"JgAsAScOKA0NKSgOJw4NKA0pDSgOKCgNDigN/ygNKA4MKCkNKQ0NKA4oDSkMKSgODSkNAAEgKA4pDQ0oJw8nDg0pDSkMKQ4oKA4MKQ3+Jw4oDg0pJw4oDg0pDSgOKAwqJw4MKQ0AASInDigODSgoDicPDCkMKgwoDSkoDg0oDv4oDicODSknDigODCkNKA0pDSknDg0pDQABIicOKA0NKCkNKQ0MKQ4oDSgOKCgODSgO/SkMKQ0NKSgNKA4NKA4oDSkMKSgODCoMAAEhKA4nDg4oKA4nDg4oDCoMKQ0pKAwOKA3/Jw4oDg0oKA4oDgwpDSgNKQ0oKQ0NKA4AASEoDigNDSkoDSgNDSkNKA0pDSknDg4oDf4oDSkNDSgpDSgNDSkNKQ0oDigoDgwpDAANBQ=="
Use this website to check your JSON file.
Your file has a mistake:
Error: Parse error on line 8:
... "speed": "toggle"],"commands": { "p
Expecting '}', ',', got ']'
Has anyone set up a Mitsubishi MSZ-WR09NA or MSZ-WR12NA? I’ve been using the 1124.json and it does most of what I need, except fan direction/angle.
Hi friends,
I’ve been using the RM4 Pro with OpenHAB for the past two years to send commands to several RF controlled ceiling fans and it’s been running great.
However, due to several reasons I’m thinking of migrating away from OpenHAB to Home Assistant.
I’ve gone over the docs of this integration on the github page, but being a non developer and a noob to the Home Assistant platform, I’m still not sure how to set it up.
Before I go through the migration process that will require recreating my whole system, can anyone tell me if there is a full tutorial to setting up the SmartIR integration?
Hope someone can help
The SmartIR integration is quite a multi-step process, but don’t be too worried, it’s only tedious for the initial setup and when learning new device codes. After that, it’s pretty easy to use, just like any other Home Assistant device entity.
Disclaimer: I’m not the maintainer, so I will not provide any form of support. This is just a post to help people get started.
Best to go through the GitHub documentation first, but in general here are the steps.
Environmental assumptions:
- You are totally new to Home Assistant but have gone through basic setup procedures already
- You are using HAOS
- Setup may differ for other Home Assistant installation methods
- You have already setup HACS
- You have already setup your RM4 Pro and integrated it to Home Assistant.
- You have a method to modify your home assistant configuration files (pick one):
- Studio Code Server Add-on
- File Editor
- SSH or other methods.
Setup Steps:
Install SmartIR via HACS - You may need to restart Home Assistant.
Obtain device IR/RF codes (Link to documentation for
climate
type devices)- If your device model can be found in SmartIR GitHub codes repository, download the code file and put it in
config/custom_components/smartir/codes/<type>/<id>.json
> - Otherwise, learn IR/RF codes if required using HA service call
remote.learn_command
, learnt commands can be found inconfig/.storage/broadlink_remote_<mac-addr>_flags.json
. - If you already have them in openHAB, you can use those as long as they are in the Broadlink base64 format.
Setup
codes
json file for your device. This JSON file tells SmartIR how to manage your device and which codes it should use.- If you found codes from the repository and placed it in your codes folder, skip this step.
- Otherwise, you’ll need to create a json file for your device.
- Browser tool here.
- Examples can be found in the repository as well.
Add device configuration to Home Assistant’s
configuration.yaml
- Examples can be found in the repository.
- Options can be found in the repository documentation, here’s a link to the climate type documentation.
Restart Home Assistant
If you’ve done this correctly, you should see your device entity listed if you search “SmartIR” in the Entities page. Click below to go to the entities page.
Thank you very much for the detailed explanation
I think I took most of the steps you mention before, but I guess I did a mistake somewhere along the way.
I’ll try again with your explanation and hopefully this time everything will work properly
Update:
Hi @samuelthng I followed your steps to the point of learning my remote codes.
However, when I am running HA’s Remote: Learn Command
service I can’t get my rf codes to be properly recorded and saved in neither the config/.storage/broadlink_remote_<mac-addr>_flags.json
or config/.storage/broadlink_remote_<mac-addr>_codes.json
files.
When I run the learn service my broadlink RM4 Pro enters into learn mode, and after pressing a button on my remote the learn service captures my remote’s frequency and I’m getting an HA notification I should now press the button I want to learn, but when I press the remote button a second time it seems that nothing is happening and the codes are not saved to the proper file.
As you mentioned I do have my remote codes that I learned for OpenHAB and I also have them in base64 format. Can you please explain how I can use those codes to create json files to control my devices?
You can take a look at the codes folder in the repository for some examples for the json files. The tool in the previous message I sent also helps to generate the shape of the json.
From there, you just need to put the file in the right directory, and ensure the codes you have are placed in the right keys.
As yours is a RF command, I’m not very familiar if there is any differences in the process. I’m using IR commands for all my devices. Maybe the RF codes are stored in a separate location.
Is Tuya IR blaster also compatible?
