I’ve got 6 rm minis around my house all using smartir
I’ve tried to add more but I think they may have a newer firmware version on them.
HA can’t control them.
The broadlink econtrol app sees them as unknown device
Inc app works.
Hi, I added a binary sensor to tell when my split type AC has been turned on not using HA, its working, as I can see the sensor change, how ever the hvac_modes do not have an on mode, I want to update the mode to the “last_on_operation:” value as that will update it to show what was last used. I can’t figure a way to update this attribute, can anyone help with this? Thanks in advance.
Hello, i am working on a infrared project that controls air conditioners, want to know how SmartIR works, and how to decode the climate codes to raw bit data, I know they are encoded with base64 but when decoding they don’t appear to be right, as LG air conditioners have 28 bits and the code data I found for commands decodes to a 8 bytes array of bits, so this data is sent to the broadlink controller this way, how can I work my way to get some raw bit pulses?
Hi, I’ve the same error. I follow the configuration steps provided. I’m running on raspberry with hassio 0.105.x. Are you able to get it working?
Thanks Bruno
Hi, I´ve the same issue. I cant use the rm mini in HA. The firmware version is v44057, sdk 2.13.23 beta, data cloud US
HA version 0.105
if it won´t work, I´ll have to change the firmware. I suppose for tasmota
Any recommendations?
thanks
All stuff is working, but I don’t understand, does it right or not.
Expected behavior: on/off button automatically setup to AC last configuration (e.g. 23 heat), I could see does AC working now or not.
Real behavior: on/off button always setup to FAN mode, then I should click another button to setup heat or cool. And, I can’t see real current status of AC.
That’s normal? Or I did something the wrong way?
Thanks.
I have created a json file for my tv reciever, and it’s working nicely.
One thing I cannot figure out is how to call speciffic buttons I created/learned?
I was using script’s before, but since I moved everything to smartIR, I cannot figure out how to call channel1 etc. in automation?
