I have it set up with the RM Mini 4, very easy installation, as long as you don’t connect the RM to the Broadlink cloud during initial setup. Just fill in the WiFi details and after those are uploaded to the RM, force close the Broadlink app.
So I’ve followed the guide. Installed SmartIR through HACS and created my own json with the AC codes because my AC it’s not on the list. What is the device code I use now? Can I use any?
Climate working fine in Smartir, but fan intigration give a error.
Log Details (ERROR)
Logger: homeassistant.components.fan
Source: custom_components/smartir/fan.py:92
Integration: Fan (documentation, issues)
First occurred: 6:42:36 PM (1 occurrences)
Last logged: 6:42:36 PM
Error while setting up smartir platform for fan
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 178, in _async_setup_platform
await asyncio.wait_for(asyncio.shield(task), SLOW_SETUP_MAX_WAIT)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 442, in wait_for
return fut.result()
File "/config/custom_components/smartir/fan.py", line 76, in async_setup_platform
hass, config, device_data
File "/config/custom_components/smartir/fan.py", line 92, in __init__
self._speed_list = [SPEED_OFF] + device_data['speed']
KeyError: 'speed'
Log Details (ERROR)
Logger: custom_components.smartir.climate
Source: core.py:1218
Integration: SmartIR (documentation)
First occurred: 10:53:17 PM (6 occurrences)
Last logged: 10:54:00 PM
Unable to find service broadlink/send
File "/config/custom_components/smartir/climate.py", line 338, in send_command
self._commands[operation_mode][fan_mode][target_temperature])
File "/config/custom_components/smartir/controller.py", line 93, in send
'broadlink', 'send', service_data)
File "/usr/src/homeassistant/homeassistant/core.py", line 1218, in async_call
raise ServiceNotFound(domain, service) from None
homeassistant.exceptions.ServiceNotFound: Unable to find service broadlink/send
Thank you for this integration, it works very well with my rm4c_mini and my Hitachi RAK-25NH6A AC using 1082.json file (even if it wasn’t listed as a supported device)
However, I was wondering if it is possible to add a sleep functionality, like I have on my remote.
I am able to “learn” the codes using the broadlink integration, but i’m not sure if smartir is designed to have a sleep function.
For the moment I am using scripts and I call directly broadlink.send service, but I was wondering if there were a better way.
Thank you
@Vassilis, I started having issues with media players controlled by SmartIr, the climate component works fine. But every time I issue a command to a media player device I started getting these:
2020-07-04 18:27:09 ERROR (MainThread) [homeassistant.core] Error executing service: <ServiceCall broadlink.send (c:67aaabda19ba483b9404cf075417f278): host=192.168.1.232, packet=[b'&\x00f\x00t8\x10\x0c\x10)\x10\x0c\x11\x0c\x10\x0c\x10\r\x10\x0c\x10\r\x10\x0c\x10\r\x10\x0c\x10\r\x10\x0c\x10)\x10\x0c\x10\r\x10\x0c\x10\r\x10\x0c\x10\r\x10\x0c\x10\x0c\x10\r\x10)\x10\x0c\x10\r\x10\x0c\x10\r\x10\x0c\x10\r\x0f\r\x10\x0c\x10)\x10\r\x10)\x10)\x10(\x10)\x10\r\x10\x0c\x10)\x10\r\x10)\x10(\x10)\x10)\x10\r\x10)\x10\x00\r\x05\x00\x00']>
File "/usr/src/homeassistant/homeassistant/core.py", line 1276, in catch_exceptions
await coro_or_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1295, in _execute_service
await handler.func(service_call)
File "/usr/src/homeassistant/homeassistant/components/broadlink/__init__.py", line 115, in async_send_packet
device = hass.data[DOMAIN][call.data[CONF_HOST]]
KeyError: '192.168.1.232'
Any idea what’s happening here? Thanks!!!
PS This is my config for this particular entity:
- platform: smartir
name: living room tv
unique_id: livingroom_tv
device_code: 1001
controller_data: 192.168.1.232
EDIT: Solved. Forgot again that unless I create a switch on the broadlink platform the smartir entities don’t work.
I edited the file 1501.json replacing just the Base64 codes with custom ones and saved the file as 1502 (no extension) in smartir/codes/climate directory.
My custom_components directory is shown below:
When checking the config I get the following error:
I thank you in advance for the assistance you can provide
Thank you @Vassilis for this incredible work. I found SmartIR by coincident. I have been using HASS for a year and never heard of it, definitely it should have more exposure through main HASS (like in official add-ons).
I was just planning how to integrate few devices in HASS and it took me under 2 hours to integrate, Gree AC and Samsung TV. I still have a fan and heater fan to add later.
here are couple of ideas that I wish SmartIR has. they are meant as feedback
In my setup, I have alexa talk to devices directly through skills. it is my redundancy strategy. so IR signals can be sent by broadlink or remotes and HASS is not aware of them.
In an ideal scenario, HASS have it is own dedicated IR receiver (on GPIO or through ESPHome, tasmota…etc.) and when it receives a signal it get processed by SmartIR to update the status of the devices in HASS so it is almost always in Sync with the real status of the device. Currently, I am planning to this manually through ESPHome
Power usage monitors becoming more and more common, I wish the power on sensor to be more flexible, to accept numbers coming from energy monitors and thus avoid the need to create a binary sensor to convert the power usage sensor.
Climate device to have full support (I saw many people wishing for that) including
Auxilary Heaters, by making Climate control other heating (climate devices) to have a robust solution. I live in Montreal, where temperatures could drop to -40 C. during beginning and end of winter, use the heat pump to warm up my apartment and when outside temperature drops to -12 I switch to electrical radiators (currently hooked to smart thermostat that shows as climate device in HASS), as the limit for heat bump is - 15. I think this scenario is very common to many folks who live in cold areas.
Possibility of adding other types devices like vacuum cleaners
Finally another gigantic thank you for the amazing work
