Hi, @radinsky.
Have you added a temperature sensor to your config? You need an external temperature sensor to display current temperature.
See example below where I have defined temperature, humidity and power sensors. A bit off-topic, but for info, the power sensor is a binary sensor I have defined to show if the AC is running or not, for example if it has been started from outside HA.
OK, strange.
I don’t have much more to add unfortunately. I expect that you have checked that the temperature sensor is supplying usable data.
You could try to add another sensor, but I really have no idea.
I just stopped by to say: Thank you!
But I will also take the opportunity to say:
What a beautiful job. I’ve been using it for years and it works perfectly.
Easy to install and configure,
Simple update,
So far without security problems,
Simply sensational!
Thank you again!
How do i include this {"Vendor":"PANASONIC_AC","Model":4,"Mode":"Cool","Power":"Off","Celsius":"On","Temp":21,"FanSpeed":"Max","SwingV":"Auto","SwingH":"Auto","Quiet":"Off","Turbo":"Off","Econo":"Off","Light":"Off","Filter":"Off","Clean":"Off","Beep":"Off","Sleep":-1} MQTT code in Json file??
For those who try to add turbo or oscilate command, but those command do not change the temp ( it’s only toggle on and off).
For now, my way of getting around the problem: I added 3 other temperatures (31, 32, 33) and I gave them the codes for “turbo on / off”, “oscillates on / off” and "postion of the +1 "oscillation. I am using a script or button that uses the command “call-service” and “climate.set_temperature” to modify them.
Pardon the basic question, but i can’t seem to find an answer anywhere.
I made a simple python script for my Sanyo RCS-3HVPSS4EE-T Remote that dinamically generates the correct command, it’s possible to have a dinamic generated base64 command instead of a fixed file with all the commands.
I need it because the remote have a temperature sensor on it and it works as a thermostat for the AC so I need to send an updated temperature every 4-5 minutes.
This is to provide feedback to SmartIR so that it knows if the device is on or off. eg: I use SmartIR to turn on/off my old AV receiver and HA (SmartIR) knows if the AV receiver is on/off based on the power_sensor, which I have setup as a template to turn on if the power consumption of the AV receiver is greater than 5 Watts.
The way it should work is that the sensor turning off is how SmartIR knows that the device (in your case, aircon) has been turned off. SmartIR will then set the climate entity to off.
To test it you could use a dummy entity and force it on/off to confirm that your climate entity is following the state
Good day! could not find where to write!
Please add to the Tosot T09H-SNA / I air conditioner, its code is the same as that of the GREE air conditioner under code 3180
