hi guys,
Is it able to get new media_player or climate entities based on smartir without restarting Home Assistant?
It seems HA support the feature to allow a custom component to reload new generated entities without restarting HA.
Thank you.
Not sure about this one. You could just turn it on and set it how you want, it will probably remember the last state. Automations or scripts are an option.
I just got a heatpump but the integration for my model isnāt working. My model is MSZ-GL15NA. I tried all the Mitsubishi one from the list but none of them had all button working. I tried to manually learn the IR code but the remote has buttons with multiple (4) functions.
What are my solutions?
Can you tell us more about one button having multiple functions? What functions? You may have to capture them separately and enter them as separate commands.
One of the button swap mode between cooling, heating, dehumidify. Another one is for the fan speed. Auto, Quitet, Super Low, Low, Medium and Fast.Same with vane position. Auto, oscillating and four disctint position. How am I supposed to capture all those different settings?
Remote control in action: Mitsubishi Ductless Remote - Simple Remote, Basic Functions - YouTube
Push the button, capture the setting. Because remotes typically send the full state (mode, temperature, etc) you need to capture all the combinations you require to send from HA. Itās fairly tedious but thereās no other option.
For example, for my air conditioner I had to record quite a bit:
- heat mode, auto fan, 18 - 24 degrees
- heat mode, medium fan, 18 - 24 degrees
- cool mode, auto fan, 18 - 24 degrees
- cool mode, medium fan, 18 - 24 degrees
etc for dry mode, fan mode, etc. It can take hours to capture them and put them into the config file, which is why I limited what I captured to only the modes / settings I actually use.
Alright I just did a few manual recording. Heat to 23C, Cool to 23C and Off. I see the ir code in the ā/config/.storageā file.
Do I have to keep the āclimateā entry in the configuration.yaml file?
Since I have only 3 button, what I can use to control my heat pump?
Have a look at the post I made #1190. Basically you need to take an existing template, give it a new number, and insert the codes in the right place. Once you have the codes the buttons are irrelevant, you control them using a thermostat control in HA.
That is going to take a while lol. Thanks!
Good afternoon, I donāt know why, when I make a change in temperature or any other option, the broadlink makes 2 equal shipments, that is, I send the signal 2 times. It only happens to me with smartir. Do you know why it can be?
Cheers
Hi, I am just trying to figure this one out.
adding my Mitsubishi AC was pretty easy, its the fan that is giving me a pain to setup. I am using a company that you probably have never heard of āCrompton Greevesā the model is Engerion
I created a custom code, by using the Remote: Learn Command
for my BroadLink RM Mini 4 and pasted it over to a new .json file in /config/custom_components/smartir/codes/fan/1075.json
Added the appropriate entry for SmartIR and the fan controls in configuration.yaml file and added the fan to my dashboard
configuration.yaml
smartir:
fan:
- platform: smartir
unique_id: office_fan
device_code: 1075
controller_data: remote.office_remote_remote
power_sensor: binary_sensor.fan_power
Dashboard - LoveLace UI
type: entities
entities:
- entity: fan.office_fan
title: Office
state_color: true
The problem is, that the fan does not turn on when I turn on the fan in the dashboard, It only turns on when I toggle the switch from the āOffā position to āOnā and back to the āOffā position, and the same for turning it off.
I donāt know how to resolve this, can someone help?
@aasimenator I guess thereās something unusual about the IR codes. Is the remote a one button on / off that toggles state, or are there two buttons? In your place Iād try recording the on / off codes a half dozen time and see if theyāre all the same or if thereās a pattern - half the same for example.
Thank you for responding, there is only one on/off button but when I learn the command in HA it is different for each button press
"Fan Test": {
"On": "JgBQAAABI5ITEhITEzcSNxMSExITEhM3EjgSOBMSEhMSNxM3EzcTEhMSEhMTEhISFBETExISExITNxI4EzcTNhM3EjgSOBI4EgAFCgABJUkTAA0F",
"Off": "JgBQAAABIpMTEhISEzcTNxMSExITEhI4EzYUNhMTERMSOBI4EjcUERMSExITEhITExISExMSEhMSNxM3EzcTNxI4EjgSNxQ2EwAFCgABJEoTAA0F",
"On 1": "JgBQAAABI5ITEhMSEzcTNhQRFBEUERM3EzcSOBMSExITNhM3EzcSExMSExISExMRFBEUERQRExITNxM3EzcTNhQ2EzcSOBM3EwAFCQABJUkTAA0F",
"Off 1": "JgBQAAABI5ITEhMSEzcTNxMRFBEUERQ2EzcTNxITEhMTNxM2FDYTEhMSExITEhMSExITEhMSExITNhQ2EzcTNxM3EzcSNxQ2EwAFCgABJUkTAA0F",
"On 2": "JgBQAAABIpIUERMSFDYTNxMSExISExM3EzYUNhMSExITNxM3EzYUERQRExITEhMSExITEhITExITNhQ2EzcTNxM3EzYUNhQ2EwAFCgABJUkTAA0F",
"Off 2": "JgBMABMSEhMTNxI4ExITERQRFDYTNxM3ExITEhM2FDYTNxMSExITEhMSExITERQRFBEUERM3EzcTNxM3EzYUNhM3EzcTAAUKAAElSBQADQU=",
"On 3": "JgBQAAABJJETEhMSEzcTNxMSExEUERQ2EzcTNxMSExISNxQ1FTYTEhMSExITEhMSExITERMSFBETNxM3EzcTNxM2FDYTNxM3EwAFCgABJUkTAA0F",
"Off 3": "JgBQAAABI5ITEhMSEjcUNhQRExITEhM3EzcTNxMRFBETNxM3EzcSExMSEhMTERQRExITEhMSExISOBI4EjcUNhQ2EzcTNxM3EwAFCgABJUgTAA0F",
"On 4": "JgBQAAABI5ISEhQRFDYUNhMSExITEhM3EzcTNhQRExITNxM3EjgTEhMRFBEUERQRExITEhMSExITNxM3EzYUNhQ2EzcTNxM3EwAFCgABJEoTAA0F",
"Off 4": "JgBUAAABI5EUERMSEzcTNxMSExITERQ2FDYTNxMSExITNxM2FDYTEhMSExITEhMSExITEhMSExITNhQ2EzcTNxM1FTcTNhQ2EwAFCgABJUkTAAUiBwANBQ==",
"On 5": "JgBQAAABJZEUERMSEzcTNxMSExITEhM2EzcTNxMSEhMTNxM3EzYUERMSExISExMSExITEhITExITNhQ2EzcTNxM3EjcUNhQ2EwAFCgABJUkTAA0F",
"Off 5": "JgBQAAABIpMSExMSEzYUNhMSExISExM3EzYTNxQRExITNxI4EzcTERMSFBETEhMSEhMTEhMSEhMSNxQ2FDYTNxM3EzcTNhQ3EgAFCgABJEoTAA0F",
"On 6": "JgBMABQRFBETNxM3ExITEhMSEjcUNhQ2ExITEhM3EzcTNhQRExITEhMSEhMSExMSEhMTEhM2EzcUNhM3EzcTNxM2FDYUAAUKAAElSBQADQU=",
"Off 6": "JgBIAAABI5EUERQREzcTNxMSEhMTEhM3EzYUNhMSExITNxM0FjcTERQRFBETEhMSExITEhMSExISOBM3EzYUNhM3EzcTNxM2FAANBQ=="
Hey!
Just created an account to thank you very much for this GREAT component.
Iāve been using it to control my 5 Fujitsu AC units with great success since june.
Thanks again!
Interestingā¦ theyāre mostly fairly similar, and it doesnāt look like on and off have their own codes, I suspect itās a toggle. I wonder if thatās just because of errors in the IR transmission and the protocol has a lot of error correction. Not really sure where to go from here though sorry.
Can I control 4 air conditioners ??? if so how can I do the configuration ??? because Iām trying and the configuration file gives me an error.
i tried this setup but it gives me invalid error
smartir:
remote:
- platform: broadlink
name: AC Cameretta
host: 192.168.1.10
mac: 'cameretta'
host: 192.168.1.6
mac: 'cucina'
host: 192.168.1.8
mac: 'salotto'
climate:
- platform: smartir
name: AC Cameretta
device_code: 1023
controller_data: 192.168.1.10
temperature_sensor: sensor.temperature
humidity_sensor: sensor.humidity
power_sensor: binary_sensor.stato_accensione
- platform: smartir
device_code: 1023
controller_data: 192.168.1.6
- platform: smartir
device_code: 1023
controller_data: 192.168.1.8
With āmac:ā you should provide the MAC-Address but not the location of the device.
Anyway, Broadlink device(s) are added through config flow of the Broadlink Integration but not through configuration.yaml anymore! Thus delete the following block and add the Broadlink devices directly through the integration:
remote:
name: AC Cameretta
host: 192.168.1.10
mac: ācamerettaā
host: 192.168.1.6
mac: ācucinaā
host: 192.168.1.8
mac: āsalottoā
As for climate/smartir here comes an example on how this is getting configured through configuration.yaml:
smartir:
climate:
- platform: smartir
unique_id: office_ac
# Model: FTC35NV14
device_code: 1110
delay: 0.5
controller_data: remote.broadlink_rm4c_6_buro_ac_remote
temperature_sensor: sensor.sonoff_snzb_02_temperature_sensor_home_office_temperature
humidity_sensor: sensor.sonoff_snzb_02_temperature_sensor_home_office_humidity
power_sensor: climate.office_ac
@SerpikoIT try removing indentation / spaces for everything from line 3 and below. Hereās my config as an example
smartir:
climate:
- platform: smartir
unique_id: daikin_kitchen
device_code: 1118
ok the mac was just to give an example, instead the configuration you posted to me is the one I have for a single air conditioner I want to add 3 how can I do ??? if I repeat the configuration it tells me that it already exists and is duplicated while modifying the settings
