morning all. So I undertook this weekend to learn all commands needed for climate control but when I transfer all 300 commands to the JSON it does not seem to want to work. the codes works independently if I use the IR send command so the commands “learned” correctly. Is there a correct way to get these codes into a JSON? once finalised and working I want to submit it to smarit to add to their list of supported devices as its a Panasonic thats not yet on their list
Anyone knows why on HomeKit it show the climate with a current temperature of 21° C even if I don’t have any temperature sensor configured ?
This is my smartir config:
- platform: smartir
unique_id: atic_ac
device_code: 1380
controller_data: remote.attic_remote_remote
And this is how it shows on HomeKit:
I have two climates and the behavior is the same. Shows 21° on both of them
Hi Dave
Can supported modules be any name in the JSON?
Good afternoon.
Does anyone have the floureon and smartir integration at the same time?..I can’t get the beok 311 thermostat and the smartir integration to work at the same time
Does anyone know how to help me set up my air conditioner?
I have a Moes UFO-R11 Zigbee IR blaster.
Through this I learned the codes of the air conditioner remote control.
How do I set this to the smartir configuration?
Do I need to generate my own JSON file? If so how do I do it? What settings do I need to write?
I’m not sure what that parameter actually does within the Integration, probably just for the user to understand which model(s) the code should work with.
Thanks.
I followed your guide but it still doesn’t work for me.
As I wrote, I have a Zigbee device connected via zigbee2mqtt to Home Assistant and yours is Broadlink. The question is how do I define this device in the JSON file? Maybe I set it wrong and that’s why nothing happens.
This is what I wrote for a test:
"manufacturer": "Gree",
"supportedModels": [
"Unknown"
"supportedController": "MQTT",
"commandsEncoding": "Raw",
"minTemperature": 25.0,
"maxTemperature": 25.0,
"precision": 1.0,
"operationModes": [
"heat",
"cool"
"fanModes": [
"low"
"commands": {
"off": "C9ciaRGbAlgGmwIkAuABA+ATD+AHG+ADN+ADC+ATJ8AbwAdAN8ALAztOmwJAD+BrAwdYBpsCJAKbAg==",
"heat": {
"low": {
"25": "B4sjWBGwAgkCgAMBXQbgAQPAE0AHQBdAB0AD4AMLQA/gDwNAJ0AD4AsfwBfAB0AjwAsDRU6wAkAP4GMDQHsLXQawAl0GsAJdBrAC"
"cool": {
"low": {
"25": "E4UjWRGzAmcGYwJjArMCCgKzAmcGgANAC8ADQBMHCgJjAgoCswKACwGzAuALAwNjArMCwBdAJ0ADwA/gAweAFwVjAmcGYwLAAQNnBrMCQBMBcE5AB+AJAwBjYAEBswLgDxvgCxcCCgJjYAEBCgJAC4ADAGMgAcALgAfADwljAmcGswJnBmMC"
In the config file of Home Assistant I tried all kinds of options but nothing worked:
- platform: smartir
unique_id: e04d18de-6a4b-460c-906c-201a877e6c29
device_code: 2019
controller_data: zigbee2mqtt/Office_RC/set
temperature_sensor: sensor.office_environment_temperature
humidity_sensor: sensor.office_environment_humidity
power_sensor: binary_sensor.office_ac_status
- platform: smartir
name: Office AC v2
unique_id: 50a0a386-66a2-40bf-8502-cfb918b9c9ab
device_code: 2019
controller_data: zigbee2mqtt/Office RC/set
- platform: smartir
name: Office AC v3
unique_id: 2cdc5ce3-c8db-4de8-867c-11bc09027d68
device_code: 2019
- platform: smartir
name: Office AC v4
unique_id: 49d2cb51-3f31-4c64-9613-8bf08eee8c31
device_code: 2019
controller_data: zigbee2mqtt/Office-RC/set
- platform: smartir
name: Office AC v5
unique_id: 3c169560-8c8c-4f83-b26f-196ade531dd8
device_code: 2019
- platform: smartir
name: Office AC v6
unique_id: 35fc40cd-fc75-4b78-941c-27a481f0f93b
device_code: 2019
- platform: smartir
name: Office AC v7
unique_id: 2d99632e-5f0e-4d02-b799-5d5aa31ab69b
device_code: 2019
controller_data: zigbee2mqtt/Office-RC/command
- platform: smartir
name: Office AC v8
unique_id: 61dedd94-76b4-41fe-a32f-75a29b246601
device_code: 2019
controller_data: zigbee2mqtt/Office RC/command
- platform: smartir
name: Office AC v9
unique_id: ab47bf07-65b9-4d9d-9ef7-46af79899131
device_code: 2019
controller_data: zigbee2mqtt/Office_RC/command
What am I doing wrong?
Only certain IR devices are supported.
Ok. Mine works through MQTT, so maybe it works with the MQTT Publish service. Am I right?
Yeah I suppose. It’s not something I’m familiar with in regards to this Integration.
Got it.
Even though it seems like it should go away, I still can’t get my head around it and find a solution.
Thanks anyway for trying to help!
try adding quotes around your mqtt topic … also in 1 spot you have a space and in another an _ so make sure thats correct,
I would recommend trying to get it working via mosquitto_pub (ie command line) to make sure you get the payload and the topic correct. The page for your specific device on the z2m site should be able to help you out.
Apologies if this has been mentioned before but I couldnt find it.
Short of an input boolean and an automation to set it, is there a better/easier way to have a fan remember state across HA reboots ?
Climate works, but fan does not.
I didn’t understand what you meant, could you please explain?
Was this you first time installing SmartIR? or was this after the recent HA core update?
Isolate the problem and address them one at a time.
Make sure your MQTT commands work first, before trying to get them to work with SmartIR.
You can do this via command line, using the command mosquitto_pub
, or using the services tab on Development Tools using the mqtt.publish
service
Hi, I have a General brand with model: ASH18LSBCW and it’s not support by SmartIR: SmartIR/CLIMATE.md at ba0b46b140796a86f85a601326cb90bbaa1b84d8 · smartHomeHub/SmartIR · GitHub
Someone know how can I add support for my AC? Someone know about some videotutorial about create json file with the codes? Because I am a beginner and I do not understand if the codes are obtained by turning the AC off and on each time or by turning it on once and then changing the temperature and speed options. Thank you
Now I understand you.
So yes, it works great through mqtt.publish
service. In SmartIR it is not.
