Yes you can copy between devices, just make sure the Mac address in the file names are unchanged.
The above is only applicable to HA integration to Broadlink and has nothing to do with SmartIR.
If you intend to use SmartIR, after successfully configuring your SmartIR entry and restarting HA, you should see a dedicated entity of the appropriate domain (eg.: media_player.some_unique_entity_id). Using the dedicated entity created by SmartIR, you can interact with your devices and SmartIR will handle all the remote service calls for you.
Iāve got some commands configured already via an ESPHome device, with a connected transmitter. Is there a simple/easy way to convert these commands into the ones used by the JSON config files?
Can anyone tell me how to use additional codes from the āIRā file of device codes for media_player, for example from ā1500.jsonā such as āNavUPā or numbers? I couldnāt find anything in the documentation on this topic.
So I did. And on/off, volume control, source switching works for me. Iām talking about additional codes in this file. How can I transfer them to my onkyo device via IR?
Seems the specific code for 26Ā°C for your device is wrong or the manufacturer of your AC has changed the code for it. You can use Broadlink Manager to check on this.
Does the little blue light on the RM4 lits whenever sending the code for 26Ā°C?
Could also be helpful to tell us the make and model of the AC unit, the SmartIR codeset you are using for it and which particular Broadlink RM4 model is in use.
Quick question. Iād like to use a Broadlink rm4 mini with SmartIR and control my heat pump via Home Assistant.
Can someone confirm that if the Broadlink receives a signal from the existing heat pump remote that the SmartIR Home Assistant integration will update accordingly? Essentially, I want my Home Assistant thermostat card to be up to date even if someone uses the remote.
No, it wonāt unfortunately. The Broadlink will only receive IR commands when you put it in ālearningā mode. This is a limitation we donāt really have a solution for.
