Hello together
I’ve made some changes to the smartlight appdaemon. After some testing it should be fine now.
What is different here:
- You may start a scene or switch on lights.
- if a light of a scene which is monitored is still on, the scene will not start
- brightness sensor can be taken to set initial light brightness
- scene and lights will have different time_outs
- entities to disable motion sensor
- entities to disable timer
Have a look which parameters are possible:
WZi:
module: smartlight
class: SmartLight
status_timers: 300
somebody_is_home_entity: group.family
light_entities:
- light.wand
- light.sideboard_rechts
- light.sideboard_links
scene_on_activate_clear_timer: clear
scene_entity: scene.scene_sensor_wohnzimmer_1
scene_timeout: 7200
scene_restart: True
scene_listen_entities:
- scene.scene_sensor_wohnzimmer_1
- scene.scene_sensor_wohnzimmer_2
- scene.hell
- scene.tv_blau
- scene.tromso_mit_licht_unten_blau_rot_dunkel
- scene.sideboard_bild_turkis
- scene.tracey_lights
- scene.scene_wohnzimmer_esszimmer_1
- scene.scene_wohnzimmer_esszimmer_2
monitor_light_timeout: 3600
monitor_light_entities:
- light.wand
- light.wohnzimmer_links
- light.wohnzimmer_rechts
- light.wohnzimmer_licht_1
- light.wohnzimmer_licht_2
- light.wohnzimmer_licht_3
- light.wohnzimmer_licht_4
- switch.lichtvorhang
- switch.lichterkette
- switch.tromso
motion_entities:
- binary_sensor.ms1
- binary_sensor.ms3
lux_entity: sensor.ms1
lux_limit: 35
brightness_entity: sensor.template_motion_sensor_light_brightness
transition: 10
light_timeout: 60
restart_timer: 'motion'
disable_motion_sensor_entities:
- input_boolean.global_motion_no_switch_light
- input_boolean.disable_wohnzimmer_motion
disable_timer_entities:
- input_boolean.disable_wohnzimmer_timer
If you want give that a try you can get it at: https://github.com/ZWOOKY-Code/appdaemon-smartlight
Sorry, didn’t have time at the moment for more documentations.
Hope it’s useful for somebody
