Started getting the below error on 10/11 and was not sure if anyone else was having an issue.
I have not received any updates since the error started.
File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 969, in _wrap_create_connection
return await self._loop.create_connection(*args, **kwargs) # type: ignore # noqa
File "/usr/local/lib/python3.9/asyncio/base_events.py", line 1081, in create_connection
transport, protocol = await self._create_connection_transport(
File "/usr/local/lib/python3.9/asyncio/base_events.py", line 1111, in _create_connection_transport
await waiter
File "/usr/local/lib/python3.9/asyncio/sslproto.py", line 528, in data_received
ssldata, appdata = self._sslpipe.feed_ssldata(data)
File "/usr/local/lib/python3.9/asyncio/sslproto.py", line 188, in feed_ssldata
self._sslobj.do_handshake()
File "/usr/local/lib/python3.9/ssl.py", line 944, in do_handshake
ssl.SSLCertVerificationError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: Hostname mismatch, certificate is not valid for 'smartmetertexas.com'. (_ssl.c:1129)
