HA green user. Sorta a newb (def a newb).
Thinking about buying smart wings but terribly confused with all the motor choices. Which is the best? I don’t have any controllers or dongles or whatever you call them. Do I need? Help! Thank you
Hi Micheal, your question is quite general with very little info so answering to it is not that easy…
You are also fairly new to the forum with not many reading hours so I would advice you to do some reading so you could better decide what suits you.
Also, have a look at Integrations - Home Assistant, there you see what kind of brands/devices can be integrated with HA (Home Assistant)
