Well I spoke too soon. I left the house at 7:40pm and when I got back I thought it was odd that the KTL was ON. It turned OFF at one point and then later turned itself back on.
I still had the SmartThings IDE open and logging events and this is what it captured.
9:39:54 PM: debug Forwarding device event to bridge: {"path":"/push","body":{"name":"Kitchen Table Light","value":"off","type":"switch"}}
9:36:53 PM: debug Forwarding device event to bridge: {"path":"/push","body":{"name":"Kitchen Table Light","value":"66","type":"level"}}
9:36:43 PM: debug Received device event from bridge: [status:OK]
9:36:43 PM: debug Received device event from bridge: [name:Kitchen Table Light, value:66, command:true, type:level]
9:36:42 PM: debug Updating subscription: {"path":"/subscribe","body":{"devices":{"notify":["Contacts","System"],"acceleration":[],"alarm":[],"battery":[],"presence":[],"button":[],"carbonDioxide":[],"carbonMonoxide":[],"hue":["Porch RGB Strip Lights"],"saturation":["Porch RGB Strip Lights"],"color":["Porch RGB Strip Lights"],"colorTemperature":[],"consumable":[],"contact":[],"door":[],"energy":[],"illuminance":[],"image":[],"level":["Porch RGB Strip Lights","Kitchen Table Light"],"lock":[],"activities":[],"currentActivity":[],"motion":[],"status":[],"trackDescription":[],"trackData":[],"mute":[],"pH":[],"power":[],"humidity":[],"switch":["Kitchen Table Light","Porch RGB Strip Lights"],"shock":[],"lqi":[],"rssi":[],"sleeping":[],"smoke":[],"sound":[],"steps":[],"goal":[],"soundPressureLevel":[],"tamper":[],"temperature":[],"heatingSetpoint":[],"coolingSetpoint":[],"thermostatSetpoint":[],"thermostatMode":[],"thermostatFanMode":[],"thermostatOperatingState":[],"threeAxis":[],"timeRemaining":[],"sessionStatus":[],"touch":[],"voltage":[],"water":[],"windowShade":[]}}}
9:21:42 PM: debug Received device event from bridge: [name:Porch RGB Strip Lights, value:on, command:true, type:switch]
9:21:42 PM: debug Updating subscription: {"path":"/subscribe","body":{"devices":{"notify":["Contacts","System"],"acceleration":[],"alarm":[],"battery":[],"presence":[],"button":[],"carbonDioxide":[],"carbonMonoxide":[],"hue":["Porch RGB Strip Lights"],"saturation":["Porch RGB Strip Lights"],"color":["Porch RGB Strip Lights"],"colorTemperature":[],"consumable":[],"contact":[],"door":[],"energy":[],"illuminance":[],"image":[],"level":["Porch RGB Strip Lights","Kitchen Table Light"],"lock":[],"activities":[],"currentActivity":[],"motion":[],"status":[],"trackDescription":[],"trackData":[],"mute":[],"pH":[],"power":[],"humidity":[],"switch":["Kitchen Table Light","Porch RGB Strip Lights"],"shock":[],"lqi":[],"rssi":[],"sleeping":[],"smoke":[],"sound":[],"steps":[],"goal":[],"soundPressureLevel":[],"tamper":[],"temperature":[],"heatingSetpoint":[],"coolingSetpoint":[],"thermostatSetpoint":[],"thermostatMode":[],"thermostatFanMode":[],"thermostatOperatingState":[],"threeAxis":[],"timeRemaining":[],"sessionStatus":[],"touch":[],"voltage":[],"water":[],"windowShade":[]}}}
9:08:58 PM: debug Forwarding device event to bridge: {"path":"/push","body":{"name":"Kitchen Table Light","value":"off","type":"switch"}}
9:06:47 PM: debug Forwarding device event to bridge: {"path":"/push","body":{"name":"Kitchen Table Light","value":"74","type":"level"}}
9:06:43 PM: debug Received device event from bridge: [name:Kitchen Table Light, value:74, command:true, type:level]
9:06:43 PM: debug Received device event from bridge: [status:OK]
9:06:43 PM: debug Received device event from bridge: [name:Porch RGB Strip Lights, value:on, command:true, type:switch]
9:06:42 PM: debug Updating subscription: {"path":"/subscribe","body":{"devices":{"notify":["Contacts","System"],"acceleration":[],"alarm":[],"battery":[],"presence":[],"button":[],"carbonDioxide":[],"carbonMonoxide":[],"hue":["Porch RGB Strip Lights"],"saturation":["Porch RGB Strip Lights"],"color":["Porch RGB Strip Lights"],"colorTemperature":[],"consumable":[],"contact":[],"door":[],"energy":[],"illuminance":[],"image":[],"level":["Porch RGB Strip Lights","Kitchen Table Light"],"lock":[],"activities":[],"currentActivity":[],"motion":[],"status":[],"trackDescription":[],"trackData":[],"mute":[],"pH":[],"power":[],"humidity":[],"switch":["Kitchen Table Light","Porch RGB Strip Lights"],"shock":[],"lqi":[],"rssi":[],"sleeping":[],"smoke":[],"sound":[],"steps":[],"goal":[],"soundPressureLevel":[],"tamper":[],"temperature":[],"heatingSetpoint":[],"coolingSetpoint":[],"thermostatSetpoint":[],"thermostatMode":[],"thermostatFanMode":[],"thermostatOperatingState":[],"threeAxis":[],"timeRemaining":[],"sessionStatus":[],"touch":[],"voltage":[],"water":[],"windowShade":[]}}}
8:51:49 PM: debug Forwarding device event to bridge: {"path":"/push","body":{"name":"Kitchen Table Light","value":"66","type":"level"}}
8:51:43 PM: debug Received device event from bridge: [name:Kitchen Table Light, value:66, command:true, type:level]
8:51:43 PM: debug Received device event from bridge: [status:OK]
8:51:42 PM: debug Received device event from bridge: [name:Porch RGB Strip Lights, value:on, command:true, type:switch]
8:36:52 PM: debug Received device event from bridge: [status:OK]
8:36:51 PM: debug Forwarding device event to bridge: {"path":"/push","body":{"name":"Kitchen Table Light","value":"74","type":"level"}}
8:36:43 PM: debug Received device event from bridge: [name:Porch RGB Strip Lights, value:on, command:true, type:switch]
8:36:43 PM: debug Received device event from bridge: [name:Kitchen Table Light, value:74, command:true, type:level]
8:36:42 PM: debug Updating subscription: {"path":"/subscribe","body":{"devices":{"notify":["Contacts","System"],"acceleration":[],"alarm":[],"battery":[],"presence":[],"button":[],"carbonDioxide":[],"carbonMonoxide":[],"hue":["Porch RGB Strip Lights"],"saturation":["Porch RGB Strip Lights"],"color":["Porch RGB Strip Lights"],"colorTemperature":[],"consumable":[],"contact":[],"door":[],"energy":[],"illuminance":[],"image":[],"level":["Porch RGB Strip Lights","Kitchen Table Light"],"lock":[],"activities":[],"currentActivity":[],"motion":[],"status":[],"trackDescription":[],"trackData":[],"mute":[],"pH":[],"power":[],"humidity":[],"switch":["Kitchen Table Light","Porch RGB Strip Lights"],"shock":[],"lqi":[],"rssi":[],"sleeping":[],"smoke":[],"sound":[],"steps":[],"goal":[],"soundPressureLevel":[],"tamper":[],"temperature":[],"heatingSetpoint":[],"coolingSetpoint":[],"thermostatSetpoint":[],"thermostatMode":[],"thermostatFanMode":[],"thermostatOperatingState":[],"threeAxis":[],"timeRemaining":[],"sessionStatus":[],"touch":[],"voltage":[],"water":[],"windowShade":[]}}}
8:21:54 PM: debug Received device event from bridge: [status:OK]
8:21:53 PM: debug Forwarding device event to bridge: {"path":"/push","body":{"name":"Kitchen Table Light","value":"66","type":"level"}}
8:21:43 PM: debug Received device event from bridge: [name:Kitchen Table Light, value:66, command:true, type:level]
8:21:43 PM: debug Received device event from bridge: [status:OK]
8:21:42 PM: debug Received device event from bridge: [name:Porch RGB Strip Lights, value:on, command:true, type:switch]
8:21:42 PM: debug Updating subscription: {"path":"/subscribe","body":{"devices":{"notify":["Contacts","System"],"acceleration":[],"alarm":[],"battery":[],"presence":[],"button":[],"carbonDioxide":[],"carbonMonoxide":[],"hue":["Porch RGB Strip Lights"],"saturation":["Porch RGB Strip Lights"],"color":["Porch RGB Strip Lights"],"colorTemperature":[],"consumable":[],"contact":[],"door":[],"energy":[],"illuminance":[],"image":[],"level":["Porch RGB Strip Lights","Kitchen Table Light"],"lock":[],"activities":[],"currentActivity":[],"motion":[],"status":[],"trackDescription":[],"trackData":[],"mute":[],"pH":[],"power":[],"humidity":[],"switch":["Kitchen Table Light","Porch RGB Strip Lights"],"shock":[],"lqi":[],"rssi":[],"sleeping":[],"smoke":[],"sound":[],"steps":[],"goal":[],"soundPressureLevel":[],"tamper":[],"temperature":[],"heatingSetpoint":[],"coolingSetpoint":[],"thermostatSetpoint":[],"thermostatMode":[],"thermostatFanMode":[],"thermostatOperatingState":[],"threeAxis":[],"timeRemaining":[],"sessionStatus":[],"touch":[],"voltage":[],"water":[],"windowShade":[]}}}
8:06:46 PM: debug Received device event from bridge: [status:OK]
8:06:43 PM: debug Received device event from bridge: [name:Porch RGB Strip Lights, value:on, command:true, type:switch]
8:06:43 PM: debug Received device event from bridge: [name:Kitchen Table Light, value:74, command:true, type:level]
8:06:43 PM: debug Received device event from bridge: [status:OK]
8:06:42 PM: debug Updating subscription: {"path":"/subscribe","body":{"devices":{"notify":["Contacts","System"],"acceleration":[],"alarm":[],"battery":[],"presence":[],"button":[],"carbonDioxide":[],"carbonMonoxide":[],"hue":["Porch RGB Strip Lights"],"saturation":["Porch RGB Strip Lights"],"color":["Porch RGB Strip Lights"],"colorTemperature":[],"consumable":[],"contact":[],"door":[],"energy":[],"illuminance":[],"image":[],"level":["Porch RGB Strip Lights","Kitchen Table Light"],"lock":[],"activities":[],"currentActivity":[],"motion":[],"status":[],"trackDescription":[],"trackData":[],"mute":[],"pH":[],"power":[],"humidity":[],"switch":["Kitchen Table Light","Porch RGB Strip Lights"],"shock":[],"lqi":[],"rssi":[],"sleeping":[],"smoke":[],"sound":[],"steps":[],"goal":[],"soundPressureLevel":[],"tamper":[],"temperature":[],"heatingSetpoint":[],"coolingSetpoint":[],"thermostatSetpoint":[],"thermostatMode":[],"thermostatFanMode":[],"thermostatOperatingState":[],"threeAxis":[],"timeRemaining":[],"sessionStatus":[],"touch":[],"voltage":[],"water":[],"windowShade":[]}}}
7:51:43 PM: debug Received device event from bridge: [name:Porch RGB Strip Lights, value:on, command:true, type:switch]
7:51:42 PM: debug Updating subscription: {"path":"/subscribe","body":{"devices":{"notify":["Contacts","System"],"acceleration":[],"alarm":[],"battery":[],"presence":[],"button":[],"carbonDioxide":[],"carbonMonoxide":[],"hue":["Porch RGB Strip Lights"],"saturation":["Porch RGB Strip Lights"],"color":["Porch RGB Strip Lights"],"colorTemperature":[],"consumable":[],"contact":[],"door":[],"energy":[],"illuminance":[],"image":[],"level":["Porch RGB Strip Lights","Kitchen Table Light"],"lock":[],"activities":[],"currentActivity":[],"motion":[],"status":[],"trackDescription":[],"trackData":[],"mute":[],"pH":[],"power":[],"humidity":[],"switch":["Kitchen Table Light","Porch RGB Strip Lights"],"shock":[],"lqi":[],"rssi":[],"sleeping":[],"smoke":[],"sound":[],"steps":[],"goal":[],"soundPressureLevel":[],"tamper":[],"temperature":[],"heatingSetpoint":[],"coolingSetpoint":[],"thermostatSetpoint":[],"thermostatMode":[],"thermostatFanMode":[],"thermostatOperatingState":[],"threeAxis":[],"timeRemaining":[],"sessionStatus":[],"touch":[],"voltage":[],"water":[],"windowShade":[]}}}
7:40:12 PM: debug Forwarding device event to bridge: {"path":"/push","body":{"name":"Kitchen Table Light","value":"off","type":"switch"}}
7:36:51 PM: debug Received device event from bridge: [status:OK]
7:36:50 PM: debug Forwarding device event to bridge: {"path":"/push","body":{"name":"Kitchen Table Light","value":"66","type":"level"}}
7:36:43 PM: debug Received device event from bridge: [name:Kitchen Table Light, value:66, command:true, type:level]
7:36:43 PM: debug Received device event from bridge: [name:Porch RGB Strip Lights, value:on, command:true, type:switch]
7:36:42 PM: debug Updating subscription: {"path":"/subscribe","body":{"devices":{"notify":["Contacts","System"],"acceleration":[],"alarm":[],"battery":[],"presence":[],"button":[],"carbonDioxide":[],"carbonMonoxide":[],"hue":["Porch RGB Strip Lights"],"saturation":["Porch RGB Strip Lights"],"color":["Porch RGB Strip Lights"],"colorTemperature":[],"consumable":[],"contact":[],"door":[],"energy":[],"illuminance":[],"image":[],"level":["Porch RGB Strip Lights","Kitchen Table Light"],"lock":[],"activities":[],"currentActivity":[],"motion":[],"status":[],"trackDescription":[],"trackData":[],"mute":[],"pH":[],"power":[],"humidity":[],"switch":["Kitchen Table Light","Porch RGB Strip Lights"],"shock":[],"lqi":[],"rssi":[],"sleeping":[],"smoke":[],"sound":[],"steps":[],"goal":[],"soundPressureLevel":[],"tamper":[],"temperature":[],"heatingSetpoint":[],"coolingSetpoint":[],"thermostatSetpoint":[],"thermostatMode":[],"thermostatFanMode":[],"thermostatOperatingState":[],"threeAxis":[],"timeRemaining":[],"sessionStatus":[],"touch":[],"voltage":[],"water":[],"windowShade":[]}}}
Are those “Updating subscription” messages causing things to change? I think I recall reading in one of the posts that someone had a similar issue but I couldn’t find that thread. Notice that the level is changing between 66 and 74 so perhaps there’s a problem syncing the level of brightness and that is causing the ON/OFF at different brightness’s?
In mqtt-spy I see both /switch and /switch/state as well as /level and /level/state.
