Smartthings and Home Assistant Link Error
Smartthings configuration issue:
Running Hass as the preconfigured vm. I Installed smartthings and it went well following the guides. UNTIL… i realized i used the wrong account. I used mine instead of another one. That’s no big deal right?! HA… Yes, after each step i rebooted the ENTIRE vm.
  1. Deleted the Smartthings integration - rebooted - error that the webhook is invalid
  2. Saw the script to remove all instances and to fix the issue (as the developer said - oh you should remove it from smartthings first –)… can’t run the python script as you have no OS availability to run CLI commands … tried doing it from windows as suggested and that didn’t work.
  3. Tried other forum posts to remove the smartthings folder in config (it just recreates it).
  4. Went to smartthings and said “remove everything” … it removes everything but the organization and same error still.
  5. Smartthings app? As others have said - no option to remove anything there and now after step 4, it doesn’t show anything.
  6. Okay…Lets reinstall the vm completely…destroyed it and recreated it and it automatically pulled the webhook in again with the same error.
  7. With new build, ensured that the proxy and config files were reset to allow the ssl to work correctly again.
  8. Turned off the vm for a day to see if it would time itself out…NOPE
  9. Looked at doing a full debian vm with Hass installed and found it STILL wants the docker container (which is silly).
SmartThings will be configured to send push updates to Home Assistant at:
https://xyz.ddns.net/api/webhook/ea49da41644de7efbd068da76aa0a0e69039f0a9d2
If this is not correct, please update your configuration, restart Home Assistant, and try again.
So i can’t add a smartthings integration, can’t get the webhook out… as it isn’t being seen anywhere…
Any thoughts on this as I’m stumped and without the smartthings integration HA Is useless for 1/2 of my devices and most zigbee, zwave, lutron want smartthings or another type of hub.
Do you have a backup from before attempting to add the SmartThings Integration.
And do you have access to another machine to run the CLI? The integration WILL NOT work until you clear out that old token association.
