I’m migrating from Samsung SmartThings to HA.
HA certainly has more features and is more flexible but one thing I sorely miss and can’t figure out how to duplicate are the “Smart Apps”.
Let’s say I wanted to tie an on/off switch to a dimmable bulb.
Instead of hard-coding the exact switch, exact bulb and exact brightness level, I could set them as user-input variables.
Then, from the ST app → Automations: I would get a menu where I would select a switch, a bulb and what brightness level I wanted. Then the automation would run with those settings.
I could easily change those parameters when needed, w/out having to dig through actual code.
See example screen shot below, this if from a more complicated automation that controls a ceiling fan speed based on temperature and if the TV is on or off:
Is there a way to do something similar in HA?
NodeRed automations seem to provide a lot of very nice features and controls but can I replicate user-input variables that are accessible from the phone HA app?
Thank you,
Boris.
