Smartthings authentication url showing as blank?
Hi All,
I’ve been using HA for some time with no issues, but yesterday after getting a fault I restored by instance from a backup. It all came back online but without the smart things integration.
As it was all working, I started the configuration of smart things again.
It all went through until it gets the authentication on smart things- where the screen is just blank.
I have checked the config/.storage location but don’t have the file, I have removed the theme=smartthings, cleared cache, tried different browsers in private mode as well, but just cannot authenticate. I can login to the smart things app and can see its trying but not finished the authentication.
Any ideas?
Im having the exact same issue. Blank webpage on the strongman page.
Brand new setup of homeassistant with haos and nabucasa cloud
Ive opened https://github.com/home-assistant/core/issues/77929
Same problem with me - blank strongman API page. Did anyone ever figure this out?
how do I delete the integration to start over if it’s showing “reconfigure” screen? (no remove / delete)
Hi, go to integration tab, select Samasung smarthings and the on the hamburger menu you can delete from there
