Smartthings hubs disappeared after sd crash
Everything was working perfectly in my HA installation on Raspberry until, unfortunately, it stopped working due to an issue with the SD card. I was unable to recover the content due to many damaged sectors, but I had an (old) backup.
So, I proceeded to restore a new SD card with that backup, and to my surprise, the SmartThings integration no longer worked.
I deleted the integration and tried to reload it: I have 2 hubs in two different homes, and neither of them appear when I try to reactivate the integration.
It’s as if for some reason they have been rendered ‘unusable’. I deleted the smartapp from the phone app, and tried to check if there are any ‘ghost’ apps still active through SmartThings CLI, but none were found. I also canceled the existing token, generating a new one, but nothing changed.
I have exhausted all tests.
Has anyone experienced the same situation?
Thank you in advance for your help.
