ST integrated devices had stopped functioning, so I decided to remove the integration and re-integrate. After following the instructions, HA shows SmartThings MyStatus… no devices. I’ve restarted HA, updated to latest version, Adguard disabled (per a solution in another support inquiry herein).
Smartthings device integration seems to be failing again… I have changed nothing. Is this common? Does ST integration require to be re-integrated on a regular basis?
