I have just installed Home Assistant, but am running into trouble getting the SmartThings integration to work.
Installation is on Ubuntu 18.04 using python virtualenv. I have configured the server to use https, and am able to access and login to the installation from both inside and outside of my local network. I have checked my certificate online, and everything checks out OK.
After going through several of the suggestions I found in this thread, I am fairly certain I am missing a configuration step somewhere, but am unable to make any progress.
When entering the personal access token during integration setup, I receive the message “The base_url for the http component must be configured and start with https://.”
I have setup base_url, ssl_certificate and ssl_key under html in configuration.yaml.
I have enabled debug logging for the integration. When I enter submit with my access token, this is the only entry in the log:
DEBUG (MainThread) [homeassistant.components.smartthings.smartapp] Setup endpoint for http://192.168.0.15:8123/api/webhook/9b2a62f15a42c8fc4d1a0e26fe5c2aaa10c96d91e16f305d6cc06d30ab923462
Any suggestions on how to proceed would be greatly appreciated. Thanks!
