I’m having trouble with a SmartThings integration. I am running a newly installed version of HomeAssistantOS on an rpi4. I started the integration process before I had an external webhook, and the suggested one was on my local network. I aborted the process and set up a nabu casa account. Now when I recreate the process by adding a SmartThings integration, I get an immediate return to the integrations panel.
Here’s the underlying error. How can I clear out the previous integration information? I can’t find any reference to it in the configuration files.
Thanks.
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
resp = await self._request_handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py", line 499, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py", line 118, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 56, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 18, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 72, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 127, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 129, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 136, in post
return await super().post(request)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 60, in wrapper
result = await method(view, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 69, in post
result = await self._flow_mgr.async_init(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 130, in async_init
result = await self._async_handle_step(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 213, in _async_handle_step
result: Dict = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/smartthings/config_flow.py", line 67, in async_step_user
await setup_smartapp_endpoint(self.hass)
File "/usr/src/homeassistant/homeassistant/components/smartthings/smartapp.py", line 227, in setup_smartapp_endpoint
webhook.async_register(
File "/usr/src/homeassistant/homeassistant/components/webhook/__init__.py", line 36, in async_register
raise ValueError("Handler is already defined!")
ValueError: Handler is already defined!
