I’m trying to setup interrogation with Smartthings with running into problems with hass.io.
- Installed duckdns add-on
"lets_encrypt": {
"accept_terms": true,
"certfile": "fullchain.pem",
"keyfile": "privkey.pem"
"token": "sdfj-2131023-dslfjsd-12321",
"domains": ["my-domain.duckdns.org"],
"seconds": 300
Logged into duckdns and created an entry (xxx.duckdns.org)
I created a personal token on the Samsung site
Setup port forwarding on my router
Edited my configuration.yaml and added the following:
http:
base_url: https://my-domain.duckdns.org:8123
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
I rebooted and now I can’t get to the HA web page and having problems troubleshooting the problem. For example: How can i edit the configuration.yaml from the HA console?
Also - What step did I miss in the Smartthings integration process?
