SmartThings Integration (newby) : Edited
I am trying to follow the Home Assistant Documentation to setup the SmartThings integration. All goes fine including setting up Nabu Casa for remote connection. When I try to follow the Steps at “Setup Instructions”, and click on the SmartThings integration the UI just resets to the list of Integrations each time, no other dialogs or data entry screen show up.
Edit: I was doing this on an iPad Pro, and tried switching to a Windows device. Things progressed further, with the SmartThings API screen opening and the steps for creating the SmartApp seeming to work fine, through to the “Success” dialog. However the Integration Config dialog did not change to show “complete” or anything similar. There is no evidence in HA of the SmartThings integration in the list of configured integrations, and no evidence in SmartThings of the HA SmartApp.
None of the troubleshooting steps seem relevant.
I cant seem to find the same issue elsewhere on the forums (though I am sure its probably there somewhere).
Anyone have an idea of what I am doing wrong?
I have HomeAssistant setup on a RPi 4 using the local install (not Docker and not HomeAssistant image). Other integrations so far are working (Ambient Weather Station, Printer, Spotify, MQTT (on same RPi).
