The Smartthings Integration is now presenting water valves as binary sensor (binary_sensor.water_valve). It used to be switch (switch.water_valve). It appears in the last Smartthings update they made this change.
I have multiple automations that used to turn off the Water Valve (switch.water_valve) if a sensor detected water.
I can’t figure out how to turn off the Water Valve in HA with a binary sensor. Any suggestions…
