SmartThings Integration on DS-Lite / IPv6?
Hi there,
i really want to use the SmartThings-Integration in HA, as i have a lot of compatible devices. Unfortunately my Internet-Access is restricted to DS-Lite, so i’m limited to IPv6. But no matter what i try, there is always a blocked road, when you can’t use IPv4.
What i’ve tried so far:
I’ve tried all the tutorials using DuckDNS and other services, but all these seem to be somehow limited to IPv4.
Finally I have setup a webhook via “myFritz” (Router is a Fritzbox), which works fine so far. But as there is no NAT in IPv6, the whole communication is done over HTTP on Port 8123. SmartThings seems to require a HTTPS-Connection + valid Certificate.
I’ve setup the letsencrypt-Addon, and now i can access HA on Port 443 over HTTPS :partying_face:. Unfortunately now SmartThings still wants to communicate only on Port 8123.
I’ve tried to use the nginx-Addon as a reverese-proxy for mapping the Ports, but this seems to also not work on IPv6. :dizzy_face:
Has anybody of you managed to get SmartThings working over IPv6 or has any idea how i could be done?
Thanks a lot!
You have already proven otherwise if you can get 443.
Your issue isn’t ip6 or ds lite. Ds Lite Just means you get IPV4 by tunneling inside IPV6. Yes yojr provider might block certain ports… But that can be an issue no matter DS- lite or no.
Your issue is the second item listed under web hook. Whatever url you use to host HA externally must be accessible by smartthings. So what url are you using to access ha outside the firewall and is it properly setup ion the network settings per that doc above?
