I had Smartthings integration working fine for months. Then it just stopped working. All of my devices showed up as “unavailable” and could not be controlled by HA. But the hub is working and I can still control from Smartthings app or via Alexa using the Smartthings skill.
I deleted the Smartthings integration and also deleted the old api token in the Smartthings website. I then tried creating a new token and reinstalling the integration. HA accepts the token and says that the integration has been created, but it has no devices whatsoever. HA can’t see ANY of Smartthings devices.
What just happened??!!
I am running HA 103 on a Linux Ubuntu PC, in a docker container.
Same for me, upgraded my docker installation to 104.3 and it fixed the issue.
This is the error I had in the logs: ValueError: 'HUB' is not a valid DeviceType
If you do this, make sure you backup your config files (/srv/homeautomation/hass-config in my case) and make sure these files are not part of your container.
