I had the ST integration working fine. Then I had some network problems and had to reconfigure st. Now when I try to integrate I get to the point where it says you have to connect to st and then I get this error "{“requestId”:“8dcc3e4d-5166-34fb-ada6-d12e6961855e”,“error”:{“code”:“UnexpectedError”,“message”:“A non-recoverable error condition occurred.”,“details”:[]}}. I tried Hassio with nabu case and I did a fresh install of HA on a freenas box using duckdns and dehydration and got the same error.
here is the error I get on the machine using hassio and casa nabu
General
Server Controls
Logs
Info
Error in database connectivity during keepalive: This Session's transaction has been rolled back due to a previous exception during flush. To begin a new transaction with this Session, first issue Session.rollback(). Original exception was: (sqlite3.DatabaseError) database disk image is malformed [SQL: INSERT INTO events (event_type, event_data, origin, time_fired, created, context_id, context_user_id, context_parent_id) VALUES (?, ?, ?, ?, ?, ?, ?, ?)] [parameters: ('state_changed', '{}', 'LOCAL', '2020-10-03 13:00:50.014131', '2020-10-03 13:00:50.020878', '76138cc8057811ebbc739b2fdb6854a7', None, None)] (Background on this error at: http://sqlalche.me/e/13/4xp6) (Background on this error at: http://sqlalche.me/e/13/7s2a)
9:16:51 AM – Recorder (ERROR) - message first occurred at October 2, 2020, 1:00:51 PM and shows up 84 times
Error adding state change: This Session's transaction has been rolled back due to a previous exception during flush. To begin a new transaction with this Session, first issue Session.rollback(). Original exception was: (sqlite3.DatabaseError) database disk image is malformed [SQL: INSERT INTO events (event_type, event_data, origin, time_fired, created, context_id, context_user_id, context_parent_id) VALUES (?, ?, ?, ?, ?, ?, ?, ?)] [parameters: ('state_changed', '{}', 'LOCAL', '2020-10-03 13:15:48.668172', '2020-10-03 13:15:48.681459', '8db74608057a11eba015dff19688990d', None, None)] (Background on this error at: http://sqlalche.me/e/13/4xp6) (Background on this error at: http://sqlalche.me/e/13/7s2a)
9:16:50 AM – Recorder (ERROR) - message first occurred at October 2, 2020, 10:46:08 AM and shows up 13798 times
Error adding event: (sqlite3.DatabaseError) database disk image is malformed [SQL: INSERT INTO events (event_type, event_data, origin, time_fired, created, context_id, context_user_id, context_parent_id) VALUES (?, ?, ?, ?, ?, ?, ?, ?)] [parameters: ('state_changed', '{}', 'LOCAL', '2020-10-03 13:15:48.668172', '2020-10-03 13:15:48.681459', '8db74608057a11eba015dff19688990d', None, None)] (Background on this error at: http://sqlalche.me/e/13/4xp6)
9:16:50 AM – Recorder (ERROR) - message first occurred at October 2, 2020, 10:46:08 AM and shows up 7306 times
Config entry for ipp not ready yet. Retrying in 40 seconds
9:16:49 AM – config_entries.py (WARNING) - message first occurred at October 2, 2020, 7:08:42 AM and shows up 3329 times
Error saving events: This Session's transaction has been rolled back due to a previous exception during flush. To begin a new transaction with this Session, first issue Session.rollback(). Original exception was: (sqlite3.DatabaseError) database disk image is malformed [SQL: INSERT INTO events (event_type, event_data, origin, time_fired, created, context_id, context_user_id, context_parent_id) VALUES (?, ?, ?, ?, ?, ?, ?, ?)] [parameters: ('state_changed', '{}', 'LOCAL', '2020-10-03 13:15:18.653665', '2020-10-03 13:15:18.664833', '7bd36c69057a11eb80855bee6e78610d', None, None)] (Background on this error at: http://sqlalche.me/e/13/4xp6) (Background on this error at: http://sqlalche.me/e/13/7s2a)
9:16:49 AM – Recorder (ERROR) - message first occurred at October 2, 2020, 10:46:09 AM and shows up 7222 times
Error executing query: This Session's transaction has been rolled back due to a previous exception during flush. To begin a new transaction with this Session, first issue Session.rollback(). Original exception was: (sqlite3.DatabaseError) database disk image is malformed [SQL: INSERT INTO events (event_type, event_data, origin, time_fired, created, context_id, context_user_id, context_parent_id) VALUES (?, ?, ?, ?, ?, ?, ?, ?)] [parameters: ('state_changed', '{}', 'LOCAL', '2020-10-03 13:15:18.653665', '2020-10-03 13:15:18.664833', '7bd36c69057a11eb80855bee6e78610d', None, None)] (Background on this error at: http://sqlalche.me/e/13/4xp6) (Background on this error at: http://sqlalche.me/e/13/7s2a)
Error adding event: This Session's transaction has been rolled back due to a previous exception during flush. To begin a new transaction with this Session, first issue Session.rollback(). Original exception was: (sqlite3.DatabaseError) database disk image is malformed [SQL: INSERT INTO events (event_type, event_data, origin, time_fired, created, context_id, context_user_id, context_parent_id) VALUES (?, ?, ?, ?, ?, ?, ?, ?)] [parameters: ('state_changed', '{}', 'LOCAL', '2020-10-03 13:14:48.669276', '2020-10-03 13:14:48.679611', '69f42ec5057a11eb87657b7fa607d43b', None, None)] (Background on this error at: http://sqlalche.me/e/13/4xp6) (Background on this error at: http://sqlalche.me/e/13/7s2a)
9:16:48 AM – Recorder (ERROR) - message first occurred at October 2, 2020, 10:46:08 AM and shows up 7557 times
Host 192.168.0.78 is not available
9:16:48 AM – radarr_upcoming_media (WARNING) - message first occurred at October 2, 2020, 7:08:42 AM and shows up 3137 times
Unable to fetch data from Google Wifi
9:16:44 AM – google_wifi (WARNING) - message first occurred at October 2, 2020, 7:08:39 AM and shows up 3138 times
Platform songpal not ready yet. Retrying in 150 seconds.
9:16:41 AM – Media player (WARNING) - message first occurred at October 2, 2020, 7:08:40 AM and shows up 2085 times
[Sony Receiver(http://192.168.0.78:10000/sony)] Unable to connect
9:16:41 AM – Sony Songpal (WARNING) - message first occurred at October 2, 2020, 7:08:42 AM and shows up 519 times
Failed to connect to 192.168.0.28:7345
9:16:28 AM – VIZIO SmartCast (WARNING) - message first occurred at October 2, 2020, 7:08:43 AM and shows up 1040 times
Stream connection failed: rtsp://Mryusef1:[email protected]/live
9:16:14 AM – Stream (ERROR) - message first occurred at October 2, 2020, 7:08:53 AM and shows up 9408 times
Connection to tcp://192.168.0.14:554?timeout=5000000 failed: Host is unreachable
9:16:14 AM – components/stream/worker.py (ERROR) - message first occurred at October 2, 2020, 7:08:53 AM and shows up 9408 times
Could not connect to Shield TV at 192.168.0.8:5555 using ADB server at 127.0.0.1:5037
9:16:14 AM – androidtv (WARNING) - message first occurred at October 2, 2020, 7:08:40 AM and shows up 526 times
Couldn't connect to 192.168.0.8:5555 via ADB server 127.0.0.1:5037 because the server is not connected to the device
9:16:14 AM – /usr/local/lib/python3.8/site-packages/androidtv/adb_manager/adb_manager_async.py (WARNING) - message first occurred at October 2, 2020, 7:08:40 AM and shows up 526 times
Error fetching ipp data: Invalid response from API: Error occurred while communicating with IPP server.
9:16:04 AM – Internet Printing Protocol (IPP) (ERROR) - message first occurred at October 2, 2020, 7:08:42 AM and shows up 1136 times
Component error: external_url - Integration 'external_url' not found.
9:06:32 AM – Hass.io (ERROR) - message first occurred at 9:04:00 AM and shows up 2 times
The 'base_url' option is deprecated, please remove it from your configuration
9:06:32 AM – HTTP (WARNING) - message first occurred at October 2, 2020, 7:23:50 AM and shows up 3 times
setup_internal_discovery failed to get info for fc127ed9-94c2-4013-a6e1-68397dc97a73, Google-Cast-Group-fc127ed994c24013a6e168397dc97a73._googlecast._tcp.local.
8:49:27 AM – Google Cast (WARNING) - message first occurred at October 2, 2020, 2:07:10 PM and shows up 249 times
[Whole House(192.168.0.142):32105] Failed to connect to service Google-Cast-Group-163d939819524839b335ed39e66a1e08._googlecast._tcp.local., retrying in 5.0s
8:45:42 AM – /usr/local/lib/python3.8/site-packages/pychromecast/socket_client.py (ERROR) - message first occurred at October 2, 2020, 12:00:28 PM and shows up 173 times
[Office speaker(192.168.0.122):8009] Heartbeat timeout, resetting connection
8:45:24 AM – /usr/local/lib/python3.8/site-packages/pychromecast/socket_client.py (WARNING) - message first occurred at October 2, 2020, 11:59:58 AM and shows up 208 times
Time out fetching recording url for camera camera.backyard
8:37:53 AM – Ring (WARNING) - message first occurred at October 2, 2020, 3:42:53 PM and shows up 55 times
Update of camera.garage1 is taking over 10 seconds
8:37:53 AM – /usr/local/lib/python3.8/asyncio/events.py (WARNING) - message first occurred at October 2, 2020, 8:38:00 AM and shows up 68 times
Unable to find referenced entities light.island_light, light.ladies_bar
8:36:36 AM – helpers/service.py (WARNING) - message first occurred at October 2, 2020, 7:09:37 AM and shows up 46 times
Error reporting state - 5: Requested entity was not found.
8:36:20 AM – Home Assistant Cloud (WARNING) - message first occurred at October 2, 2020, 7:08:51 AM and shows up 234 times
Websocket connection failed, retrying in 15s: Cannot connect to host 192.168.0.10:32400 ssl:default [Connect call failed ('192.168.0.10', 32400)]
8:22:36 AM – /usr/local/lib/python3.8/site-packages/plexwebsocket.py (ERROR) - message first occurred at 8:21:45 AM and shows up 3 times
[1st Floor(192.168.0.116):32110] Error communicating with socket, resetting connection
7:55:00 AM – /usr/local/lib/python3.8/site-packages/pychromecast/socket_client.py (WARNING) - message first occurred at October 2, 2020, 2:06:58 PM and shows up 48 times
[1st Floor(192.168.0.116):32110] Error reading from socket.
7:55:00 AM – /usr/local/lib/python3.8/site-packages/pychromecast/socket_client.py (ERROR) - message first occurred at October 2, 2020, 2:06:58 PM and shows up 48 times
Error fetching Ring device data: 401 Client Error: Unauthorized for url: https://api.ring.com/clients_api/ring_devices?api_version=9
4:43:43 AM – Ring (WARNING)
Error purging history: (sqlite3.DatabaseError) database disk image is malformed [SQL: DELETE FROM states WHERE states.last_updated < ?] [parameters: ('2020-09-17 10:12:12.456745',)] (Background on this error at: http://sqlalche.me/e/13/4xp6)
4:12:00 AM – Recorder (WARNING)
Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: DELETE FROM states WHERE states.last_updated < ?] [parameters: ('2020-09-17 10:12:12.456745',)] (Background on this error at: http://sqlalche.me/e/13/4xp6)
4:12:00 AM – Recorder (ERROR)
Error handling message
October 2, 2020, 11:42:30 PM – /usr/local/lib/python3.8/site-packages/hass_nabucasa/iot.py (ERROR) - message first occurred at October 2, 2020, 11:42:23 PM and shows up 2 times
Can't handle request-connection without backend
October 2, 2020, 11:42:30 PM – /usr/local/lib/python3.8/site-packages/hass_nabucasa/remote.py (ERROR) - message first occurred at October 2, 2020, 11:42:23 PM and shows up 2 times
Updating wyzeapi binary_sensor took longer than the scheduled update interval 0:00:05
October 2, 2020, 10:13:46 PM – Binary sensor (WARNING) - message first occurred at October 2, 2020, 8:37:55 AM and shows up 51 times
Error doing job: Unclosed connection
October 2, 2020, 6:53:19 PM – runner.py (ERROR) - message first occurred at October 2, 2020, 7:08:53 AM and shows up 3 times
192.168.0.99: Connecting to HUB failed with error: [Errno 113] Connect call failed ('192.168.0.99', 5222)
October 2, 2020, 6:29:31 PM – /usr/local/lib/python3.8/site-packages/aioharmony/hubconnector_xmpp.py (ERROR)
Login attempt or request with invalid authentication from 192.168.0.3 (192.168.0.3) (Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/85.0.4183.121 Safari/537.36)
October 2, 2020, 5:33:20 PM – HTTP (WARNING) - message first occurred at October 2, 2020, 5:33:20 PM and shows up 2 times
Fetched https://remotestate.nabucasa.com/request_sync (500)
October 2, 2020, 5:28:19 PM – /usr/local/lib/python3.8/site-packages/hass_nabucasa/cloud_api.py (WARNING)
Error doing job: Task exception was never retrieved
October 2, 2020, 5:28:19 PM – components/webhook/__init__.py (ERROR)
October 2, 2020, 5:20:41 PM – components/cloud/alexa_config.py (ERROR) - message first occurred at October 2, 2020, 1:00:50 PM and shows up 27 times
Updating wyzeapi switch took longer than the scheduled update interval 0:00:30
October 2, 2020, 5:04:45 PM – Switch (WARNING) - message first occurred at October 2, 2020, 5:03:15 PM and shows up 4 times
API error setting up the SmartApp: {'requestId': '57627A09-0199-4ABF-BC26-9EB3CBF46350', 'error': {'code': 'ConstraintViolationError', 'message': 'The request is malformed.', 'details': [{'code': 'TargetTimeoutError', 'target': 'https://yusefntosia.duckdns.org/api/webhook/2a09bb2417cdad368af05db8234be67b3139dcd23fbd16735f5f8c57000d4749', 'message': 'Upstream target timed out', 'details': []}]}}
October 2, 2020, 7:20:45 AM – smartthings (ERROR) - message first occurred at October 2, 2020, 7:16:21 AM and shows up 3 times
Exception in _async_prefs_updated called from File "/usr/local/lib/python3.8/runpy.py", line 194, in _run_module_as_main return _run_code(code, main_globals, None, File "/usr/local/lib/python3.8/runpy.py", line 87, in _run_code exec(code, run_globals) File "/usr/src/homeassistant/homeassistant/__main__.py", line 320, in <module> sys.exit(main()) File "/usr/src/homeassistant/homeassistant/__main__.py", line 312, in main exit_code = runner.run(runtime_conf) File "/usr/src/homeassistant/homeassistant/runner.py", line 133, in run return asyncio.run(setup_and_run_hass(runtime_config)) File "/usr/local/lib/python3.8/asyncio/runners.py", line 43, in run return loop.run_until_complete(main) File "/usr/local/lib/python3.8/asyncio/base_events.py", line 603, in run_until_complete self.run_forever() File "/usr/local/lib/python3.8/asyncio/base_events.py", line 570, in run_forever self._run_once() File "/usr/local/lib/python3.8/asyncio/base_events.py", line 1859, in _run_once handle._run() File "/usr/local/lib/python3.8/asyncio/events.py", line 81, in _run self._context.run(self._callback, *self._args) File "/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py", line 458, in _handle resp = await handler(request) File "/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py", line 119, in impl return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 18, in request_context_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 72, in ban_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 127, in auth_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 129, in handle result = await result File "/usr/src/homeassistant/homeassistant/components/cloud/http_api.py", line 141, in error_handler result = await handler(view, request, *args, **kwargs) File "/usr/src/homeassistant/homeassistant/components/cloud/http_api.py", line 232, in post await cloud.logout() File "/usr/local/lib/python3.8/site-packages/hass_nabucasa/__init__.py", line 194, in logout await self.client.cleanups() File "/usr/src/homeassistant/homeassistant/components/cloud/client.py", line 128, in cleanups await self.prefs.async_set_username(None) File "/usr/src/homeassistant/homeassistant/components/cloud/prefs.py", line 179, in async_set_username await self._save_prefs({**self._prefs, PREF_CLOUD_USER: None}) File "/usr/src/homeassistant/homeassistant/components/cloud/prefs.py", line 344, in _save_prefs self._hass.async_create_task(async_create_catching_coro(listener(self))) Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/components/cloud/google_config.py", line 161, in _async_prefs_updated await self.async_sync_entities_all() File "/usr/src/homeassistant/homeassistant/components/google_assistant/helpers.py", line 152, in async_sync_entities_all res = await gather( File "/usr/src/homeassistant/homeassistant/components/google_assistant/helpers.py", line 148, in async_sync_entities return await self._async_request_sync_devices(agent_user_id) File "/usr/src/homeassistant/homeassistant/components/cloud/google_config.py", line 148, in _async_request_sync_devices resp = await cloud_api.async_google_actions_request_sync(self._cloud) File "/usr/local/lib/python3.8/site-packages/hass_nabucasa/cloud_api.py", line 16, in check_token await cloud.auth.async_check_token() File "/usr/local/lib/python3.8/site-packages/hass_nabucasa/auth.py", line 168, in async_check_token if not self._authenticated_cognito.check_token(renew=False): File "/usr/local/lib/python3.8/site-packages/pycognito/__init__.py", line 287, in check_token raise AttributeError("Access Token Required to Check Token") AttributeError: Access Token Required to Check Token
October 2, 2020, 7:15:51 AM – util/logging.py (ERROR)
You are using a custom integration for wyzesense which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
October 2, 2020, 7:14:40 AM – loader.py (WARNING) - message first occurred at October 2, 2020, 7:08:37 AM and shows up 4 times
Found duplicate device name Yusef Phone
October 2, 2020, 7:08:41 AM – Mobile App (WARNING) - message first occurred at October 2, 2020, 7:08:41 AM and shows up 2 times
Using slower stringprep, consider compiling the faster cython/libidn one.
October 2, 2020, 7:08:39 AM – /usr/local/lib/python3.8/site-packages/slixmpp/stringprep.py (WARNING)
Error setting up entry ecobee for ecobee
October 2, 2020, 7:08:39 AM – components/ecobee/__init__.py (ERROR)
Log Details (ERROR)
Logger: homeassistant.components.smartthings.config_flow
Source: components/smartthings/smartapp.py:145
Integration: smartthings (documentation, issues)
First occurred: October 2, 2020, 7:16:21 AM (3 occurrences)
Last logged: October 2, 2020, 7:20:45 AM
API error setting up the SmartApp: {'requestId': '6436D59E-B7D6-4CF6-918F-76250EABB6AB', 'error': {'code': 'ConstraintViolationError', 'message': 'The request is malformed.', 'details': [{'code': 'TargetTimeoutError', 'target': 'https://yusefntosia.duckdns.org/api/webhook/2a09bb2417cdad368af05db8234be67b3139dcd23fbd16735f5f8c57000d4749', 'message': 'Upstream target timed out', 'details': []}]}}
API error setting up the SmartApp: {'requestId': '5D6E59F0-07D1-43C0-B93A-1FBADF102553', 'error': {'code': 'ConstraintViolationError', 'message': 'The request is malformed.', 'details': [{'code': 'TargetTimeoutError', 'target': 'https://yusefntosia.duckdns.org/api/webhook/2a09bb2417cdad368af05db8234be67b3139dcd23fbd16735f5f8c57000d4749', 'message': 'Upstream target timed out', 'details': []}]}}
File "/usr/src/homeassistant/homeassistant/components/smartthings/config_flow.py", line 131, in async_step_pat
app, client = await create_app(self.hass, self.api)
File "/usr/src/homeassistant/homeassistant/components/smartthings/smartapp.py", line 145, in create_app
app, client = await api.create_app(app)
File "/usr/local/lib/python3.8/site-packages/pysmartthings/smartthings.py", line 123, in create_app
entity = await self._service.create_app(app.to_data())
File "/usr/local/lib/python3.8/site-packages/pysmartthings/api.py", line 180, in create_app
return await self.post(API_APPS, data)
File "/usr/local/lib/python3.8/site-packages/pysmartthings/api.py", line 404, in post
return await self.request("post", self._api_base + resource, data=data)
File "/usr/local/lib/python3.8/site-packages/pysmartthings/api.py", line 377, in request
raise APIResponseError(
pysmartthings.errors.APIResponseError: Unprocessable Entity (422): {"requestId": "57627A09-0199-4ABF-BC26-9EB3CBF46350", "error": {"code": "ConstraintViolationError", "message": "The request is malformed.", "details": [{"code": "TargetTimeoutError", "target": "https://yusefntosia.duckdns.org/api/webhook/2a09bb2417cdad368af05db8234be67b3139dcd23fbd16735f5f8c57000d4749", "message": "Upstream target timed out", "details": []}]}}
please help
