SmartThings MQTT Bridge - Update current status
I was running into issues with Battery and other states not being sent except when updated which was rare for some devices. I submitted a PR to the Github for the Bridge to get the current state during each update - this runs each time you save your Bridge and every 15 minutes so now I have accurate readings regardless of the last time the device sent an update.
See here if you are interested in the changes - PR hopefully will be merged soon:
https://github.com/stjohnjohnson/smartthings-mqtt-bridge/pull/67
This is a fantastic patch! Thank you @kylerw as I too had the same issue with battery states not updating.
There is one slight issue with Three Axis data from SmartThings Multi Sensors.
When I add your patch the data pulled looks like this:
When your patch is removed the data returns to normal:
If I trigger a sensor (while your patch is active) normal values will appear back inside HASS but after a 15 minute update occurs the data will pull back incorrectly. Any thoughts on how to fix this?
Hmm, let me that a look and I’ll let you know what I can find.
If you look at the log from the bridge, can you see anything around your Three Axis device that might help??
Think I found a fix - I don’t have any ThreeAxis devices so I had to use a simulated one. Give it a shot and let me know if it works.
I’ve updated the PR or, on or around line 493, change:
def currval = device.currentValue("${attribute}")
to
def currval = device.currentState("${attribute}").value
That seems to have fixed everything instantly.
I’ll keep an eye on it but so far so good. Thanks for creating this patch @kylerw it’s very helpful! :slight_smile:
