I’m having trouble setting up a MQTT Cover using the Smartthings MQTT Bridge with a Linear Garage Door Opener. My bridge is setup using a Mosquitto broker and everything is working great, but I just can’t seem to be able to find the proper configuration for my garage door opener. I found this configuration on github, however, this configuration was based on the old “garage_door” component and not the “cover” component. I switched “garage_door” to “cover” and this allows me to bring in the cover command interface to the front-end and I can also use an automation to send a Pushover notification when the garage opens and closes, but I can’t actually control the garage door. The only way I can control it is by using a separate switch, but the switch only allows me to open the garage door and not close it.
I’m wondering if perhaps my command_topic is incorrect. Has anyone else have any luck setting this up a linear garage door controller with the smartthings-mqtt-bridge?
Having the exact same issue. This was working in prior versions of HA, when there was a garage component - this stopped working for me once the Cover component was released. I can see the MQTT close and open messages making it to smartthings via live logging, but am unsure how to further debug this…
I’ve tried this exact same configuration and I still can’t control the door except for using the switch component in the front end, but this only allows me to open the garage door.
Are you using the “cover” component in your groups.yaml file to control your door? Or are you using the “switch” component?
An odd thing happened tonight. I tried operating the garage door using the cover component in my front end and eveything worked fine. It’s weird too because I didn’t change a single thing in my configuration. Perhaps a recent HA upgrade fixed the problem I was having. Whatever the issue was, it’s been fixed. I can confirm that your setup worked for me. Thanks for posting!
Hey guys… so I seem to have this working somewhat, where as I get a notification in the broker when I invoke actions via the smart things app. For example in the logs of mqtt-smarthings
Oct 25 09:13:23 ubuntu docker[19266]: info: Incoming message from SmartThings: smartthings/Primary Garage/door = closing
Oct 25 09:13:24 ubuntu docker[19266]: info: Incoming message from MQTT: smartthings/Primary Garage/door = closing
Oct 25 09:13:24 ubuntu docker[19266]: info: Skipping duplicate message from: smartthings/Primary Garage/door = closing
Oct 25 09:13:29 ubuntu docker[19266]: info: Incoming message from SmartThings: smartthings/Primary Garage/door = closed
Oct 25 09:13:29 ubuntu docker[19266]: info: Incoming message from MQTT: smartthings/Primary Garage/door = closed
Oct 25 09:13:29 ubuntu docker[19266]: info: Skipping duplicate message from: smartthings/Primary Garage/door = closed
Oct 25 09:13:29 ubuntu docker[19266]: info: Incoming message from SmartThings: smartthings/Primary Garage/contact = closed
Oct 25 09:13:29 ubuntu docker[19266]: info: Incoming message from MQTT: smartthings/Primary Garage/contact = closed
Oct 25 09:13:29 ubuntu docker[19266]: info: Skipping duplicate message from: smartthings/Primary Garage/contact = closed
and if I subscribe to all the topics I see some events
Publishing to the contact topic won’t get you anything, but publishing to the door topic should.
When you trigger the door to open via smartthings do you see the coresponding MQTT command? I just see the close ones in your post. Just curious if smartthings is sending the open ones too. Might be a config issue on smartthings.
I have mine configured as a cover, so I just use the cover.close_cover or the cover.open_cover service to control mine so I dont know if I ever tried to just publish to the topic, but it should work.
@johntdyer Just FYI I was in same boat with SmartThings only for GD00Z-4. I built my own Garage Door opener instead. It still uses MQTT but much easier to setup.
It works perfect. So perfect I now trusted automating my garage door to open when I arrive home.
