I am trying to get Smartthings mqtt working, just like everyone else
I’m running ubuntu in a VM on an ESXI host, smartthings & HASS VM are on different vlans. I’ve tried to point the smartthings MQTT device to both my public and private IP. My only guess is that my MAC address is somehow incorrect.
I am able to see traffic coming in on port 2080 from my router, and if I browse to http://myaddress:2080 I see “Cannot GET /”
Smartthings-Bridge Config
{ "broker_host": "10.10.120.11", "broker_port": 1883, "preface": "smartthings", "state_suffix": "state", "command_suffix": "cmd", "login": "username", "password": "password", "bridge_port": 2080 }
starting version 3.2.2 info: Starting SmartThings MQTT Bridge - v1.3.4 info: Loading configuration info: Loading previous state info: Perfoming configuration migration info: Saving current state info: Connecting to MQTT at mqtt://10.10.120.11:1883 info: Configuring autosave info: Configuring API info: Listening at http://localhost:2080
MQTT-Broker
“plain”: true,
“ssl”: false,
“anonymous”: false,
“logins”: [
“username”: “username”,
“password”: “password”
“customize”: {
“active”: false,
“folder”: “mosquitto”
“certfile”: “fullchain.pem”,
“keyfile”: “privkey.pem”
}starting version 3.2.2
1516915070: mosquitto version 1.4.12 (build date 2017-06-01 13:03:46+0000) starting
1516915070: Config loaded from /etc/mosquitto.conf.
1516915070: Opening ipv4 listen socket on port 1883.
1516915070: Opening ipv6 listen socket on port 1883.
1516915070: Warning: Mosquitto should not be run as root/administrator.
1516915082: New connection from 10.10.120.11 on port 1883.
1516915082: New client connected from 10.10.120.11 as mqttjs_9001c0b3 (c1, k10, u’username’).
1516915104: New connection from 172.30.32.1 on port 1883.
1516915104: New client connected from 172.30.32.1 as hass-1 (c1, k60, u’username’).
My homeassistant config.yaml
mqtt:
broker: localhost
discovery: true
discovery_prefix: smartthings
protocol: 3.1
keepalive: 60
client_id: hass-1
username: username
password: password
