Just to follow up on this thread, I just disconnected my Smartthings hub and put it in the waste box. I plugged a HUSBZB-1 into my HA Raspberry Pi and configured it. When I first tried to pair the Smartthings multi-sensor, the functionality was very limited. Based on the recommendations here, I removed the device from the config and paired it with the magnet attached. PERFECT - all functionality is in place.
Thanks to all who contributed to this thread. Awesome community!
I dont want to hijack this thread, but I am looking for details from someone who’s recently got the husbzb-1 working. Are you using the zigbee home automatation integration and the deprecated zwave intregration and/or modifying the config.yaml? I’m a little unclear the best route to go here, seems like i dont need the zwave/zigbee config entries anymore? and it seem like maybe i should be using a zigbee2mqtt and zwave js instead?
I’m going to try and reset my husbzb if I can ever figure that out, as some devices just show up and I’d like to repair everything, they’re behaving oddly.
I got the tilt sensor working through a really janky automation where I hard coded on the axis I could tell I was rotating about.
I just used the Developer Tools → Events → Listen to events subscribed to “zha_event”.
I have not figured out how to intentionally poll the device for it’s position though. I’m only able to “remember the last place it was”
@ejkeebler
I was able to get exactly what you are describing working this week.
Just wanted to make this more visible to the next person who has this issue. The sensor will not pair correctly without the magnet contact being made!!! Struggled for 3 days on and off until I found this comment.
To be clear, still no X, Y, Z axis values but acceleration and temp works well.
I have a couple of these sensors and I have followed the advice to pair with the magnet next to it. This results in the temp, battery, motion showing up correctly but open/close reports as IAZ Zone and is Off when closed and On when open.
Any ideas on how to remap the device class so it correctly interprets the on / off and open / closed?
I wanted to add my own experience trying to connect a Samjin multi sensor using a Sonoff Zigbee 3.0 USB dongle. Had the above issues. Temp, Open/Close worked fine first pairing. Motion would not. I tried both with the magnet and without the magnet connected. What worked for me was going into the device screen and doing a reconfigure device. When I did this, it picked up the motion portion and is now working as expected.
I’m have a very similar issue. The open close is identified as ias_zone and the states being Wet / Dry. They do however update consistently when the door opens or closes.
Having some trouble figuring out how to specify a custom device class and previously mentioned. Any information or references to do this would be appreciated.
@Tibs .Could you please explain that with more details and the steps to achieve that. I just migrate from ST to HA and use the sensor as a garage door tilt sensor. Temp and moving state work fine. Just open / close not ! Thank you in advance
