Managed to get my smartthing system integrated to HA - very nice! I don’t seem to be able to change the setpoint on my Danfoss radiator valves though. I can do this on in my SmartThings app but I can’t change it in my HA app.
Any suggestions where to look / how to fix that?
I have a hall thermostat as well and that works fine.
Trying to bump this up as I still can’t find a solution to it. The TRV’s in question is the Danfoss LC13, If I use the standard Smartthings Device Handler, the setpoint can’t be changed in HA this appears to be a known issue. There is a custom handler as well which does allow you change the set point, but strangely - you can’t do that in automations (the option isn’t presented). This custom handler also doesn’t work in the new ST app which is another issue.
Any suggestions from anyone how to get this to work with HA?
