I have two SmartThings motion sensors, one v4 and one v5. I have added both via ZHA (Aeotec USB stick). They both function, except the v5 shows “Unknown” for the battery level. The v4 shows the battery fine, including voltage.
I note that the v4 has the quirk:
zhaquirks.smartthings.motionv4.SmartThingsMotionV4
The v5 sensor has no quirks. I wonder if v5 does not work because of the configuration otherwise found in that quirk. Is there a way to manually assign a quirk? I cannot actually find any references in the config directory.
Hi Zane, I have a number of the 2015 model but added one recently which reports as motionv5 but says it is unsupported , did you add the support yourself as per the instruction ?
