I followed the instructions setting up the PAT, HA Cloud and webkooks, but when I setup the integration, I get an error message.
After entering the token, the proper location (only one) is popping up. When I submit, I get a new window with an incomplete error message:
I’m having the same issues. Posted about it on github and another user commented they were having the same problem. I don’t have an answer for you but it helps to know it’s not your fault. It’s something in the integration that’s not working.
Also having the same problem. I previously had SmartThings integration configured but I’m not sure exactly when it stopped working. Tried removing/re-adding the integration today and get the error.
Edit: Chrome dev tools shows a 500 Internal Server error. Per Samsung’s API documentation “A non-recoverable error condition has occurred. Indicates a problem occurred on the SmartThings server that is no fault of the client.”
I’m having the same issue, I switched to Home Assistant from smartthings a few days ago and the initial integration went smooth and everything worked fine. I noticed several of my z-wave devices that were available throught the smartthings integration were no longer working. I tried removing the smartthings integration and starting over but got the webhook error.
here is my log message.
Logger: homeassistant.components.webhook
Source: components/webhook/init.py:84
Integration: Webhook (documentation, issues)
First occurred: 7:08:14 PM (22 occurrences)
Last logged: 7:52:42 PM
Received message for unregistered webhook xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx from 192.168.1.200
I even completely deleted Home Assistant and all the left over config files and did a fresh install and get the same error. I’m using unraid.
edit: my smartthings setup is still working without issue.
I read through that thread but didnt have access to try it out until now. I feel like something must have changed on samsungs side since yesterday. I’m no longer getting that error screen in the browser anymore like i did before, however I am now having a new issue.
when setting up the smartthings integration, I input my token from smartthings (generated a fresh one), then i advance to the next screen and pick my home location from the drop down like normal. but then I no longer get redirected to the browser, I instead get a new popup window in HA that simply says “aborted”. Checking the logs shows I’m getting the same error message I posted previously. Tried the integration process from my pc and my iphone, both get the same aborted popup.
in frustration i restarted HA, smartthings, unraid, and the server its running on and generated another new token and then i got the error in the browser again and deleted the theme portion as instructed in the other thread and it worked. really strange. hopefully it doenst prove to be buggy.
