The swedish weather service have a open API but my programming skills are not near good enough to make a component for it. Hoping that someone that reads this might give it a go!
http://opendata.smhi.se/apidocs/metfcst/index.html
Bara lĂ€gga till med i âIntegrations\Set up a new integrationâ med long & lat sĂ„ dyker den upp i HA. Dvs om du kör 0.8.1 iaf
Yup, har redan lagt till den?
Ăr du Helto?
Does not work any more after upgrade to 0.84.2.
Cheers
Kim
Hi Kim
To bad but it works fine for me with 0.84.3, both lovelace and âoldâ gui.
/LA
Hi!
Iâm on 0.86.4
SMHI only works with the States UI, when I switch to Lovelace it does not show anything when I add it to the GUI.
Well, I have to admit that I was using Edge on my work computer. There the weather card did not work in Lovelace. But once I got home and browsed in from my home computer using Chrome the SMHI card was back in LovelaceâŠ
Is it possible to change the language for the SMHI API?
In the SMHI API thereâs a parameter âtstmâ - Thunder probability.
I cant see this value in HA, maybe Im looking in the wrong placeâŠ
But if it was avalible you could use it for a thunder warning system. It would probably be more reliable then the solution I have in place right now. Working on a AppDaemon app for a better solution, but Im kinda new so it goes very slow. See bad code below for thunder_sensor.
Is there anyone who could include this value into the normal HA integration if it isnt there already?
Thunder_sensor code(change X and Y to log/lat with three decimals to get it to work:
- platform: rest
resource: "https://opendata-download-metfcst.smhi.se/api/category/pmp3g/version/2/geotype/point/lon/X/lat/Y/data.json"
authentication: basic
headers:
User-Agent: Home Assistant
Content-Type: application/json
scan_interval: 1800
value_template: '{{ value_json.timeSeries[0]["parameters"][16]["values"][0] }}'
unit_of_measurement: " % "
This goes into configuration.yaml
//Hagalund
Similar to the above, I noticed that the SMHI integration doesnât include a couple of useful attributes avaliable through the SMHI API. Iâm using wind values as part of my awning automation and would be exited to have the following included.
- Wind gust speed
- Mean value of total cloud cover
Could someone with the proper skills include this in the SMHI integration I would be grateful!
