Hi, did somebody had the same problem and can help?
I got a new electricity meter installed a short while ago and try to read it thru the SML port.
- Manufacturer is Logarex
- Device is LK13BE606739
I could not find a manual for the meter but it seems that the data stream is binary and not in ASCII format.
I used the ESP Home SML functionality and tried different UART configs. The UART debug clearly shows that there are data being received, but is is largely 0x00.
Example:
[15:49:39][D][uart_debug:196]: <<< 0b00000000 (0x00)
[15:49:39][D][uart_debug:196]: <<< 0b00000000 (0x00)0b00000000 (0x00)
[15:49:40][D][uart_debug:196]: <<< 0b00000000 (0x00)0b00000000 (0x00)
[15:49:41][D][uart_debug:196]: <<< 0b00000000 (0x00)
[15:49:42][D][uart_debug:196]: <<< 0b00000000 (0x00)0b00000000 (0x00)
[15:49:43][D][uart_debug:196]: <<< 0b00000000 (0x00)
[15:49:44][D][uart_debug:196]: <<< 0b00000000 (0x00)
[15:49:45][D][uart_debug:196]: <<< 0b00000000 (0x00)
[15:49:46][D][uart_debug:196]: <<< 0b00000000 (0x00)
[15:49:47][D][uart_debug:196]: <<< 0b00000000 (0x00)
[15:49:48][D][uart_debug:196]: <<< 0b00000000 (0x00)0b00000000 (0x00)
[15:49:49][D][uart_debug:196]: <<< 0b00000000 (0x00)
[15:49:50][D][uart_debug:196]: <<< 0b00000000 (0x00)0b00000000 (0x00)
[15:49:51][D][uart_debug:196]: <<< 0b00000000 (0x00)
The data streams stops if I remove the IR reader from the port.
So it seems that my first problem is the UART configuration (?).
Second problem might be that the ESP Home SML needs a ASCII stream.
Did somebody run into the same problems with this particular meter or a comparable and could share a solution?
Many thanks!
PS: Reading the other information port that just gives power data (with a different ESP sensor) works just fine, but does not differentiate the direction of the energy flow.
