SMLight Z2MQTT (Broker) not working
I replaced my sonoff z2mqtt stick with a SLZB-06 POE stick. After deleting the mqtt broker as wel as z2mqtt integration, i set up both integrations again. I did this because I had a lot of devices that I do not use anymore and it was quite a mess.
After configuring both add-ons, it looked like it was working fine. I could add devices in the Z2MQTT integration, and it was showing the entitities. But once i tried to make an automation with the devices, it was not showing the needed entities. For example, i can only see the ‘do not disturb’ entity for a light bulb. Even though i can turn this light on and off in the z2mqtt intregration. I also have tested several lights. It looks like it has something to do with the mosquitto broker, but I can’t figure out what… Can anyone help me out?
