Smoke detector rfxcom systematic name change
I have a Chacon 34131 smoke detector, which works in radio frequency 433mhz, when a test with the detector launches, hassio finds it well, but once added to my sensors, its state does not change any more, if I make again a test it changes ID.
Each time I add the detector it changes ID, so I can’t monitor it via Hassio.
I’m under Hassio 0.69.1, I had the same problem under 0.68.1
I configured my sensor well in configuration.yaml, but that doesn’t change anything.
Ex:
Summary
platform: rfxtrx
devices:
0a52080000301004d240259:
I’m looking for how to define the ID and keep it that way.
Thank you in advance.
DOESIT.
I have the same problem with this:
https://www.banggood.com/433MHZ-Wireless-PIR-Motion-Detector-for-Home-Alarm-Home-Security-p-941723.html?rmmds=myorder&stayold=1&cur_warehouse=CN
and
https://www.banggood.com/VStarcam-AF117-Wireless-433mhz-Frequency-Door-Window-Sensor-Detector-for-Vstarcam-C37-AR-IP-Camera-p-1056242.html?rmmds=myorder&stayold=1&cur_warehouse=CN
