So do submit a new device support request issue for tracking and look into testing adding that model to the Tuya smoke (ts0601_smoke.py) ZHA Device Handler (quirk) and submit a pull request if you get it working:
Dont use zigbee home automation, use zigbee2mqtt, there are several videos, i.e.
I used zigbee home automation i think it is based on ZAH, and my motions sensor was not exposing values, so i use zigbee2mqtt, and it resolved my problem.
My Heiman smoke sensor is on the way, as soon i received, i will show you the setup.
@irtza This Zigbee section in Home Assistant community forum is meant to be about Home Assistantäs built-in ZHA integration (which is Home Assistant’s native Zigbee gateway component) → Zigbee Home Automation - Home Assistant
Regesless, Zigbee2MQTT also need similar device handlers but they call them “converters” so if it exposes it means someone added it to their Tuya smoke device handler → Support new devices | Zigbee2MQTT
