Is there any way to have a smoke sensor MQ2 , connected directly to GPIO as the DHT sensor?
@fabaff
thank you for the prompt help.
the Binary sensor update just shows (?) a on/off state.
I’ve allready have a PIR and a DHT11 on the GPIO.
i’m thinking about a analog sensor to read values 0-1024 as a temp or humidity in the DHT11 (or 22).
could this be accomplished with the binary sensor ?
No, you need an analog input.
@fabaff
would something between the One wire Sensor and DHT component be feasable ?
i do have a DHT connect directly to the GPIO
Onewire and DHT are software-based solution but the MQ2 which I know only have a digital and an analog output. THe most elegant solution would be I2C, from my point of view.
Would be possible with a library as DHT read the MQ2 analog PIN value?
I don’t think so but this may depends on the breakout board.
the MQ2 breakout board works with Arduino GPIO without any special code
int analogSensor = analogRead(smokeA0);
Serial.print("Pin A0: ");
Serial.println(analogSensor);
would this be interest enough to suggest as feature ?
analogRead()
is for an analog pin. As far as I know aren’t there any analog pins available on most single board computer. It would work with A/D converter perhaps which is connected through I2C.
To integrate this sensor use:
or take an ESP8266/ESP32 and MQTT.
