✨ Smooth Hold-to-Dim / Brighten✨
:sparkles:Smooth Hold-to-Dim / Brighten​:sparkles:
This blueprint lets you control any light, group, or area using a 2-button remote with event entities (such as multi-press and hold events). It offers single-press toggles, double-press shortcuts, and a smooth duration-based dimming/brightening calculation when holding down the buttons.
Features
  • Button 1 Single Press: Turns target lights on immediately.
  • Button 1 Double Press: Sets target lights to 100% brightness instantly.
  • Button 1 Hold & Release: Smoothly ramps brightness up.
  • Button 2 Single Press: Turns target lights off.
  • Button 2 Hold & Release: Smoothly ramps brightness down.
Requirements
  • Home Assistant: 2024.1.0 or newer (uses modern action syntax and event entities).
  • Compatible Remote: Any 2-button remote that exposes event entities supporting multi_press_1, multi_press_2, long_press, and long_release event types.
    • Tested & Works Great With: IKEA BILRESA (E2489)
Inputs
  • Button 1 Event Entity: The event entity associated with Button 1 (e.g., UP / Brighten).
  • Button 2 Event Entity: The event entity associated with Button 2 (e.g., DOWN / Dim).
  • Reference Light Entity: A specific light entity used to sample the current brightness percentage before starting a dimming/brightening operation.
  • Target Lights / Area: The target entities, devices, light groups, or entire area you want to control.
Installation Options
Option 1: Import via Badge
Click the My Home Assistant import badge at the top of the post.
Option 2: Manual Import
Import a blueprint from this address: https://gist.github.com/Blightbuster/f1673ce4be3be068dbb7f7086092f4df
Usage
  1. Go to Settings > Automations & Scenes > Automations.
  2. Click + Create Automation.
  3. Select Remote Light Control with Smooth Hold-to-Dim.
  4. Map your remote event entities and choose your reference light and target entities/areas.
  5. Save and enjoy smooth remote light adjustments!
YAML Blueprint Code
Summary
blueprint:
  name: Button Light Control with Smooth Hold-to-Dim
  description: >
    Controls light brightness using a 2-button remote with single-press, double-press,
    and smooth hold-to-dim/brighten features based on press duration.
  domain: automation
  input:
    button_1_entity:
      name: Button 1 Event Entity
      description: The event entity for Button 1 (e.g., Up/Brighten button).
      selector:
        entity:
          domain: event
    button_2_entity:
      name: Button 2 Event Entity
      description: The event entity for Button 2 (e.g., Down/Dim button).
      selector:
        entity:
          domain: event
    reference_light:
      name: Reference Light Entity
      description: >
        The specific light entity used to read the current brightness state during dimming operations.
      selector:
        entity:
          domain: light
    target_lights:
      name: Target Lights / Area
      description: The lights, group, or area to control.
      selector:
          entity:
            domain: light
mode: restart
triggers:
  - trigger: event.received
      entity_id: !input button_1_entity
    options:
      event_type:
        - multi_press_1
      entity_id: !input button_2_entity
    options:
      event_type:
        - multi_press_1
    options:
      event_type:
        - long_press
    options:
      event_type:
        - long_press
    options:
      event_type:
        - multi_press_2
conditions: []
actions:
  - choose:
      # --- BUTTON 1 HELD: Brighten ---
      - conditions:
          - condition: trigger
            id:
              - button_1_held_down
        sequence:
          - variables:
              ref_light: !input reference_light
              start_time: "{{ now().timestamp() }}"
              start_brightness: >-
                {{ (state_attr(ref_light, 'brightness') | float(0) / 2.55) | round(0) }}
              target_transition: >-
                {% set start = (state_attr(ref_light, 'brightness') | float(0) / 2.55) | round(0) %}
                {{ [(100 - start) / 20, 0.1] | max }}
          - parallel:
              - action: light.turn_on
                target: !input target_lights
                  transition: "{{ target_transition }}"
                  brightness_pct: 100
                continue_on_error: true
              - sequence:
                  - wait_for_trigger:
                        options:
                          event_type:
                            - long_release
                      brightness_pct: >-
                        {% set elapsed = now().timestamp() - start_time %}
                        {% set added_pct = (elapsed / 5) * 100 %}
                        {% set final_pct = start_brightness + added_pct %}
                        {{ [final_pct | round(0), 100] | min }}
      # --- BUTTON 2 HELD: Dim ---
      - conditions:
            id:
              - button_2_held_down
        sequence:
          - variables:
                {{ [start / 20, 0.1] | max }}
          - parallel:
                  brightness_pct: 1
              - sequence:
                  - wait_for_trigger:
                        options:
                          event_type:
                            - long_release
                      brightness_pct: >-
                        {% set sub_pct = (elapsed / 5) * 100 %}
                        {% set final_pct = start_brightness - sub_pct %}
                        {{ [final_pct | round(0), 1] | max }}
      # --- BUTTON 1 SINGLE PRESS: Turn On ---
      - conditions:
            id:
              - button_1_pressed_once
        sequence:
              transition: 0
      # --- BUTTON 2 SINGLE PRESS: Turn Off ---
      - conditions:
            id:
              - button_2_pressed_once
        sequence:
          - action: light.turn_off
              transition: 0
      # --- BUTTON 1 DOUBLE PRESS: Full Brightness ---
      - conditions:
            id:
              - button_1_pressed_twice
        sequence:
              brightness_pct: 100
I can’t test at the moment but it’s likely this would work with RODRET remotes as well yeah?
If so I’m excited to see what the fancy dimming does on my lights.
I dont have a RODRET so cant test it myself but as long as it has a Single Press and Hold & Release event for each button, it will work.
In case it doesnt, feel free to tell me which events it supports and i’ll add some more state to the script such that it works with more basic events.
This is great - just works!
One thing I missed from the direct binding of a Bilresa to a Kajplats bulb is that it can also switch colours.
I don’t know if this is possible, but right now it seem like “double press” the last buttons is doing nothing - is there a way with HA that when you double press it, that it can switch the “smooth” up down action from dimming to hue or temperature (depending on what features are enabled for the target bulb)
It would require some form of “state” memory I guess, which I’m not sure HA supports, as this is what I guess would store the feature to target.
I am new to HA, and to Matter and Zigbee tbh - I’m a long term user of basic consumer smart home stuff, but this is a whole new world.
I updated it such that it now only dims currently enabled lights and double pressign Button 2 now dims to 1%.
Unfortunately all my testing with double press to cycle through hue/temp felt awafull or didnt work cause there needs to be some way of stopping and there doesnt seem to be a double press hold event or an event at all when holding on the second press (at least on my IKEA Bilresa remotes)
I happen to also have the Bilresa, and was brought here because I’m in much the same boat as @Jon .
By default it does not have any double press + hold behaviour, instead it goes in steps. If at max warmness and made even warmer it’ll loop back around to being all the way cool and vice versa.
Also I’d love if you could explain some of the wizardry going on in tbe blueprint, anything I was able to make myself was jittery and slow.
Also I came across something somewhere saying that sending a “brightness up 0” would allow for smooth transitions, it was in trying to find that thread again I stumbled onto this.
Either way, I’m really happy with it so far! Thank you for your work.
This… has made the bulb function almost as well as it did before I hooked it up to HA.
