SMS controlled Alarm Panels in Home Assistant? Now available through this add-on
Hello everyone!
About 2 years ago I’ve made my first tries with integrating my ‘dumb’ and ‘non-integrable’ alarm panel: Satel Perfecta. I’ve decided to use an easiest way of integration - through SMS commands (yeah, I know there’s a protocol developed by manufacturer, and they use it in their applications - Perfecta Control, and Perfecta Soft - but I decided to leave it for the real geeks!)
Long story short: in nodejs I’ve created a simple, bi-directional mqtt2sms broker + mapper allowing me to map MQTT communication between MQTT Alarm Integration and my Satel Perfecta.
You can find it right here: GitHub - infrat/mqtt2sms-broker: A core library for nodejs serverless applications
It’s been a while since I wrote this broker, I’ve been using it successfully for the last 2 years. Since its installation presented some difficulties to many people, a few days ago I decided - finally - to create an add-on wrapping this application and greatly improving the integration process.
You can try it here:
Enjoy!
P.S. It’s my first add-on, and it’s pretty ‘fresh’. There’s a lot of room for improvement there - especially when it comes to documentation. In the near future I will try to add to it, improve and edit it. Nevertheless, I invite you to contribute!
P.S 2. I would put more links here, to shed more light on the subject but as a new user I can post here only two links
Thank you for sharing your work.
You might want to consider including a short paragraph in your documentation about interoperability if users already have an mqtt broker addon set up for other devices.
Yeah! That’s good idea, thanks for the suggestion. I’m using zigbee2mqtt and I assumed that having MQTT broker running is obvious, what’s of course is wrong assumption.
