SMS Notification: reply to sender
Hello!
I managed to get SMS Notification work by using a SIN800C USB board.
But how can I make an automation answer to the sms sender?
For example, if I send “Light off”, it triggers an automation that shuts off all the lights, and I would to send back something like “all light are off”. I can do it.
But if my wife do the the same, all I know, for now, is to put our 2 phone numbers so we will both be notified. What I want if my automation grab the sms.incoming_sms phone number and respond to it.
Is there a way to do it?
Thanks!
Do you get the phone number in the event?
If you listen for the event and then send an sms, do you get the phone number there?
Developer tools → events
this is what you have in the event:
event_type: sms.incoming_sms
phone: “+33XXXXXX”
date: “2023-03-15 13:43:53”
text: TEST
origin: LOCAL
time_fired: “2023-03-15T12:44:15.742369+00:00”
context:
parent_id: null
user_id: null
So yes, the sender’s phone number is here :slight_smile:
In that case I believe
{{ trigger.event.data.phone }}
should be the phone number you can use to send a reply
if you set up an automation to trigger on sms.incoming_sms
There is were I put your command:
And it’s not working :frowning:
Remove any sensitive data and post the automation in yaml. inside a code block </> sign in forum
There it is:
> alias: TEST
> description: ""
> trigger:
>   - platform: event
>     event_data:
>       text: TEST
> condition: []
> action:
>   - type: turn_off
>     device_id: *************
>     entity_id: light.cuisinebulb
>     domain: light
>   - service: notify.sms
>     data:
>       message: >-
>         Eteindre toutes les lumières : lumiere all off  /  mode absent : absent
>         [on/off]
>       target:
>         "[object Object]": null
> mode: single
Target is bot reflecting what is type in the cell in graphical automation !
Replacing the target with:
target: {{ trigger.event.data.phone }}
Don’t work either :frowning:
Try and surround it with “” like this:
   target: "{{ trigger.event.data.phone }}"
And please use the correct formatting, it makes reading the code hard when you use blockquote
It’s working very well, thanks a lot !
