SMTP Integration not working
Hey you guys!
I’m an IT-gal in training and one of my excersises is to set up the HA and receive e-mail notifications (MS 365) via SMTP.
Now all I get is a (for me) cryptic troubleshoot: “value should be a string @ data[‘target’][0]
I tried out many things but it still won’t work. ChatGPT doesn’t know either.
So maybe you have some input for me?
This is my yaml.config:
alias: SMTP Versand Server
description: SMTP Server-Versand
  - platform: numeric_state
    entity_id:
      - sensor.tp357_a0f1_temperature
    for:
      hours: 0
      minutes: 0
      seconds: 0
    above: 22
  - service: notify.notify
      message: >-
        "Achtung! Die Temperatur im Serverraum übersteigt 22°C. Bitte
        kontrolliere die Klimaanlage."
        platform: smtp
        server: smtp.office365.com
        sender: ***************
        port: 587
        timeout: 5
        encryption: STARTTLS
        username: *************
        password: ****************
        recipient: **************
        sender_name: HomeAssistant Helmut
mode: single
Thank you so much!!!
That’s normal, don’t use it to help with HA.
As per the docs linked in VDRainer’s post, you seem to have combined the notify: setup and the service call in the automation.
You need the notify: block set up in configuration.yaml, then the action: part of your automation is much shorter — and the target is just the recipient address.
Your target needs to be an email address i.e. target: [email protected]
This needs to be in your configuration.yaml file in the config directory.
Like
notify:
- name: Helmut
platform: smtp
port: 587
timeout: 5
After the edit restart, check in developer. then edit the automation
Guys! Thank you so much for helping out!
It worked just fine and now I receive mails from HA!
Big thanks to you too!
I had a bit of trouble setting up the SSH since my SD card did not have the config.yaml file. But I solved that and after inserting the config-file everything went smoothly and easily :slight_smile:
Glad to help!
