Did you ever figure this out? I’m seeing the same thing. Seems like I can hop to a terminal and do a random host lookup and it’ll work a couple times but then randomly fails.
In my case it was the Matter add-on causing Python to return a hostname with invalid UTF-8 characters. If you don’t have that, take a look at disabling one of your other add-ons until it works. It seems random what hostname Python returns, but it seems it’s always related to one of the add-ons that uses websockets. For example, right now mine is returning the esphome one. I solved it by removing the Matter add-on, which I wasn’t using anyway. The comment from me above about disabling Matter didn’t permanently solve it refers to the integration, but removing the add-on did solve it permanently.
➜ ~ python
Python 3.11.6 (main, Oct 4 2023, 06:22:18) [GCC 12.2.1 20220924] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import socket
>>> socket.gethostbyaddr('homeassistant.local.hass.io')
('core-silabs-multiproto', ['core-silabs-multiproto'], ['172.30.32.1'])
But I don’t really see disabling zigbee support as a viable workaround.
Did you try SMTP now? In my experience notify works as long as the socket.gethostbyaddr doesn’t return the exact same UTF-8 error. That is, I could reproduce the error in Python when it wasn’t working.
Previously running the notification service part of my automation would randomly fail within a few calls and now I’ve been able to manually trigger it over 15 times without an error. Great, but a temporary solution. I hope your bug report sees some traction soon.
I can’t remember now what I did but at one point I was able to see the actual offending hostname, non-UTF-8 characters and all, which is how I knew to disable the Matter add-on. But if you aren’t running Matter there goes my hypothesis that Matter add-on is the problem.
I’m using Zigbee2MQTT. I bought an Eve Matter motion sensor and tried to pair it with Smartthings but gave up and returned it because I couldn’t get it to work. So I’m only using Zigbee for now and haven’t seen any good Matter devices, at least that I could use.
At one point I played around to see what add-on was providing the hostname, I figured either the first or last add-on loaded at restart, but I gave up. It seems to vary with every restart.
