I tried setting up the SMTP service for email notifications etc. but I just can’t get it to work.
Below is the current code I have in the config. I tried variations of that (as found in some threads) as well, but nothing has worked. I also tried gmail, without any luck.
The service never shows up as a notify.xxx service and therefore can’t be used.
Any ideas what might be the problem?
(I am not a developer and don’t have a lot of experience with coding. So far I got pretty much everything I needed running on HA, but this seemingly easy service just won’t work. Please excuse me if I’m overlooking something obvious.)
You need to send the mail to a different account not to yourself. GMX has disabled that since June 2022. Had the same issue ( notify not showing in services ). Once I set it up like this it worked again.
When you use Developer Tools/Services does it show in the drop down as Notifications: Send a notification with mailgmx_smtp?
The documentation tells you to look for a notify.xxxx but it actually shows up as above.
I had a recent problems setting up smtp with gmail. Errors were showing up in my log though. Do you see anything in your log?
To get it working, all I did was change the order of my commands to exactly match the documentation and switch to a different supported port and voila it started to work.
I hope you’re able to get this working. I know how frustrating it is.
