SMTP Notification - Log Files?
I’ve set up a Notify like the following:
Set up logs like this:
logger:
default: info
logs:
homeassistant.core: warning
homeassistant.components.mqtt: warning
homeassistant.components.notify: debug
I can run the notify.andysms from the developer tools, but I do not get an email and I do not see the logs for notify anywhere. I’m sure I am missing something, but unsure where. I’m using Blue Iris and it sends emails no problem using the same server, sender, port, login/pass, and “use a secure connection (TLS/SSL required)” that I expect from the encryption line in the config.
