SMTP Notify calling service failed
While trying to call the SMTP notify service the service failed. From sudo systemctl homeseer.service the following were messages I received
Feb 23 14:08:34 raspberrypi hass[13031]: 2019-02-23 14:08:34 INFO (MainThread) [homeassistant.components.http.view] Serving /api/websocket to 192.168.0.24 (auth: False)
Feb 23 14:08:34 raspberrypi hass[13031]: 2019-02-23 14:08:34 INFO (MainThread) [homeassistant.components.http.view] Serving /api/config to 192.168.0.24 (auth: True)
Feb 23 14:08:34 raspberrypi hass[13031]: 2019-02-23 14:08:34 INFO (MainThread) [homeassistant.components.http.view] Serving /api/states to 192.168.0.24 (auth: True)
Feb 23 14:18:35 raspberrypi hass[13031]: 2019-02-23 14:18:35 INFO (MainThread) [homeassistant.components.http.view] Serving /api/states to 192.168.0.24 (auth: True)
Any idea what I need to edit to change the authorisation of api/websocket to true
