SMTP notify failure on startup
Has anyone noticed that their SMTP notify is failing to start after updating to 0.100? My SMTP has not been working anymore after the update. On the logs I only get this:
Error setting up platform smtp
  File "/usr/local/lib/python3.7/smtplib.py", line 387, in getreply
    line = self.file.readline(_MAXLINE + 1)
  File "/usr/local/lib/python3.7/socket.py", line 589, in readinto
    return self._sock.recv_into(b)
  File "/usr/local/lib/python3.7/ssl.py", line 1071, in recv_into
    return self.read(nbytes, buffer)
  File "/usr/local/lib/python3.7/ssl.py", line 929, in read
    return self._sslobj.read(len, buffer)
socket.timeout: The read operation timed out
  File "/usr/src/homeassistant/homeassistant/components/notify/__init__.py", line 78, in async_setup_platform
    platform.get_service, hass, p_config, discovery_info
  File "/usr/src/homeassistant/homeassistant/components/smtp/notify.py", line 84, in get_service
    if mail_service.connection_is_valid():
  File "/usr/src/homeassistant/homeassistant/components/smtp/notify.py", line 157, in connection_is_valid
    server.quit()
  File "/usr/local/lib/python3.7/smtplib.py", line 984, in quit
    res = self.docmd("quit")
  File "/usr/local/lib/python3.7/smtplib.py", line 421, in docmd
    return self.getreply()
  File "/usr/local/lib/python3.7/smtplib.py", line 391, in getreply
    + str(e))
smtplib.SMTPServerDisconnected: Connection unexpectedly closed: The read operation timed out
It was working fine before the update but I did not find anything related to notify or smtp on release notes…
No problems here with smtp notify on 0.100.2.
After multiple reboots its seems to have gone back up. Nothing changed on my side so there must have been something else wrong.
